Home | HP | OfficeJet k60 All-In-One InkJet Printer | Lines down middle of cop...
HP OfficeJet k60 All-In-One InkJet Printer
Problem for HP OfficeJet k60 All-In-One InkJet Printer
Lines down middle of copy and fax
By barbschroede on Jan 21, 2009
When we make a copy or try to fax anything - the copy comes out with lines down the middle of the copy or fax - it makes it impossible to read.
Same Problem
Feb 07, 2009
-   I have lines down the page of my copies. How do I clean the scanner glass?-   kathydensley
Solution #1
posted on Jan 31, 2009
Not Rated)
leroyal
Rank: Wiz  HP Expert
Rating: 80%, 1101 votes
You probably have a bad SCANNER ASSEMBLY.
Try opening up the document feeder and cleaning the scanner glass
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet k60 All-In-One
Questions and Unsolved Problems for HP OfficeJet k60 All-In-One
Do you recommend HP OfficeJet k60 All-In-One InkJet Printer?
Answer
Answer
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple... (More)
Answer
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has... (More)
Answer
How do I scan a document? I am getting a message that indicates that the options are not set.
Answer
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink.... (More)
Answer
Opened printer - pieces of paper stuck in roller in back - can't seem to open
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet k60 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
