Question about Home
Do you have any helpful hints on how to cork a bottle of wine properly?
    Guru:
  • 269 Answers
The most important secret to corking a bottle of wine is to make sure that the corkscrew enters the cork at a straight angle. If it doesn't, it becomes easier for the cork to chip and thereby decreasing the value of your wine.
Posted on Jan 10, 2013
My wine cellar is not cooling down at all, the fan is running and it blows air in the inside also but never cools down
You should lay the bottles on their sides. This is not just for keeping the corks moist, although that is also very important (and anything worth cellaring for an extended period of time will have a classic cork closure.) Laying the bottles on their side, while keeping the cork moist, will also allow all sediment that settles out of mixture within the wine to be collected along the side facing the ground. When you remove the bottle, keep that side down and decant it to remove the sediment before drinking.
Also, make sure the humidity in the basement is appropriate for wine storage. It should be approximately 70%. If more, it can mold the corks and spoil your investment (and, more importantly, your drinking!) https://bestsleepersofabed.com/cheap-sleeper-sofa-beds
Oct 08, 2017 | Furniture
How to make wine bottle windchimes
17 steps to make wine bottle wind chimes -
1. Gather empty wine bottles, ideally, you're are going to need at least 3 bottles.
2. Remove labels.
3. Wash the bottles.
4. Grab a glass cutter and score around the bottle using a
clamp as your guide.
5. Cut 3 bottles and sand the sharp edges to prevent cuts.
6. Get 3 corks.
7. Acquire 6 3/4 hooks.
8. Buy at least 2 feet (0.6 m) of jewelry chain.
9. Screw the hook on top of the cork.
10. Attach the chain to the hook.
11. Push the cork back on top of the bottle.
12. Repeat steps for the other bottle.
13. For the last or bottom bottle of the chime get a metal earring or any accessory.
14. Attach it to the chain. this will make sounds as the wind blows into your chime.
15. Accessorize the end of the chain if you prefer.
16. Carefully connect all three bottles.
17. Hang somewhere where air passes and listen to relaxing sound it makes!
Mar 12, 2017 | Furniture
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 | Home
How to open wine bottel
https://www.realsimple.com/food-recipes/shopping-storing/beverages/open-bottle-wine
https://www.wikihow.com/Open-a-Bottle-of-Wine
Use a sommelier tool, ie, the one with a corkscrew, a little knife, and the 2-step lever thing.
Otherwise, a corkscrew: in both cases, cut the top off the protective covering on the top of the bottle (the foil), start the corkscrew part with some downward pressure in the center part of the cork, and turn clockwise. then use the rest of the device to leverage out the cork. In the worst case, use a screwdriver to screw in a screw into the cork, and pull the cork out with pliers.
Invest in a wine vacuum pump and store the red wine at room temp, white wine in the fridge.
.....of course, for screw tops, just unscrew the bottle as you would with soda pop.
Feb 21, 2014 | DOUGLASS HILL Brut 750ML
Why do people smell the corks from wine bottles?
The cork can sometimes relay whether the wine is not good. If you smell something bitter or maybe a scent of vinegar, your wine may not be good.
Feb 03, 2013 | Wine & Spirits
I received a rack that holds the wine bottles upside down, does this effect the wine?
No, it is Ok keeping the wine this way. One ofthe most important things about keeping wine is to make sure the wine insidethe bottle is reaching the cork from inside keeping it moist, and that'sobviously happens when the bottle is maintained upside down.
May 29, 2012 | Furniture
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
How do I open a bottle of wine without a wine opener?
You can push the cork into the bottle and extract it by using a cloth napkin inserted
into the bottle. It pinches against the cork and allows it to be pulled back out.
There may be a video on youtube about this.
May 03, 2011 | Microwave Ovens
A cork is stuck in my Oster Electric Wine Bottle Opener.. It spins and spins but will not move up or down. How can I fix this?
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Dec 28, 2010 | Sunbeam Oster Electric Wine Bottle Opener
Home Logo
677 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
