Question about Nikon COOLPIX L18 Digital Camera
The lens extension is stuck more than halfway out.
The lens cannot be pushed in or pulled out. Sometimes the "lens error" message has appeared on the screen, but today it is just humming. The only way to turn it off is to take the batteries out. Thanks for your help.
  • 3 more comments
  • ecawegener Jan 23, 2009
    Thank you for the information. I appreciate it very much.
  • flygirl2_jon Feb 23, 2009
    i am having the same problem and I need to get my photos off my internal memory. Anyway to do this? I've tried to plug my USB cord into my computer but the camera doesn't register. Any suggestions?
  • rojas_karina Mar 01, 2009
    my Nikon is being so weird i put new batterys after it gets low battery and still it says low battery also my lens get stuck alot an now its still STUCK
    AHHHH!!!..........Help MEEEEEEEEEEEE
  • Anonymous Mar 10, 2009
    Lens will go open or close. Sent to Sony for what I thought would be warranty repair. Told me warranty will not cover the repair. Over $100.00 to repair and send back. More than I paid for the camera. Very frustrating.
  • Anonymous Mar 12, 2009
    I am having the same problem. The camera has not been dropped and is only a few months old.
    Sometimes it will reset, only to have Lens Error pop up in red again.
    Problem Solver:
  • 8 Answers
Hate to be the bearer of bad news, but when this problem occurs, about 90% of the time, it needs to be sent in for repair, and if not under warranty, can cost as much as the camera to fix.
Posted on Jan 22, 2009
The lens is stuck halfway in on my samsung camera i have tryed tapping it
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 07, 2011 | Samsung L110 red Including Charger,...
Shutter failing to open when you press the ON button. The zoom lens seem to be stuck and an error message "E18" is being registered.
Lens errors (E18 Errors on older Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 11, 2009 | Canon PowerShot A85 Digital Camera
Lens stuck open ,
Aug 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Error on lens
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Fuji Zoom Error Message
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 13, 2009 | Fuji Finepix J50 Digital Camera
Lens error, restart camera message
Nov 15, 2008 | Canon PowerShot S3 IS Digital Camera
Cannon A70 lens stuck in middle causing it to keep powering off
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 06, 2008 | Canon PowerShot A70 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 29, 2008 | GE A730 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
176 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
