Wat does dh mean on portable airconditioner
When runing in auto mode kicks back to DH mode
old marine
  • 2128 Answers
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
Posted on Jul 30, 2008
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
Posted on Mar 04, 2009
  • 5 Answers
SOURCE: how do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Posted on Nov 09, 2009
SOURCE: Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Posted on Nov 24, 2009
SOURCE: installing new paper in canon p26-dh ii
looked over P1-DHV Calculator found slot on top back middle of machine where paper goes in easy then up into machine with paper feed
Posted on Jan 06, 2010
HOE TO MAKE RESET FOR THIS WASHER MACHINE
Unplug the machine from the mains supply for at least 10 to 20 minutes and try again.
Dec 16, 2015 | LG Washing Machines
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
The heater will not kick on in auto setting
HAS IT ALWAYS BEEN LIKE THIS OR JUST RECENTLY STARTED DOING THIS?
Dec 27, 2012 | Heating & Cooling
My hybrid in park engine keeps runing
This system is computer controlled so you must have the dealer test it with a special scanner to determine the cause of this.
Oct 31, 2012 | Ford Cars & Trucks
360 desktop wit Window Xp. Hardware (CDROM -PLDS DH-16AAS DVDRW) installing problem
Two items on a single IDE ribbon cable require a master and a slave. The next step is to let BIOS know of the drive. Press F2 during boot and check. Look for it were other drives are, and there maybe a auto select / discovery option. It must show in BIOS, or there is no going forward.
If BIOS sees it and XP does not. Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Walla CD-ROM in the house.
If none of this works. Test another cable, CD-ROM, or computer. Oh yea, virus protection. Do a thorough scan. This was a common problem back in the day.
Oct 12, 2012 | Dell OptiPlex 360 Desktop Computer
Forgot how to load paper
Hello.
From FixYa Support:
While looking at the front of the P23-DH printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then, cut the paper on the roll straight across. Then, feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed through and you are ready to go.
Hopes this helps.
Mar 14, 2010 | Canon P23-DH Calculator
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Problems with Furnace
On is just the blower fan nothing else, check to see if there is a reset button in the tstat or tripped over load inside the furnace, inside the furance is some safetys, you will see wires runing from each other and finaly to the gas valve, push each untill one of them clicks,then your furnace should start back working, but I would still have someone come out and check why it tripped, because as I said it is a safety, and when it tripps it is for a reason.
Oct 19, 2008 | Heating & Cooling
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
