Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Door heater
Door heater between cooler side and freezer side is very hot. Is there a t-stat or a limit switch in that circuit
  • 1 more comment
  • cowboys88 Jan 22, 2009
    Great, Thanks. The condenser motor was seized up. I have the warranty, but have to locate the info. May pick up a stack motor for temp fix til then. thanks again
  • sslaughter4 Jan 23, 2009
    The middle piece is very hot, but the freezer and fridge are still cooling fine. What can i do?
  • Anonymous Mar 28, 2014
    The doors rubber casings are hot and the metal stripe in the door frame is very hot.
  • 410 Answers
This isnt an electric heater in between the doors its a hot gas loop. there is a motor behind the refrig that cools the comp and condenser coils this fan is either not working or something has jammed it up. just pull the refig away from the wall remove the compartmnet cover and check that fan out good luck peyton
Posted on Jan 22, 2009
Post between freezer and refrigerator doors is hot
I have seen a programme on TV which showed a cable between the doors which over time with constant opening and closing became worn. I should contact the manufacturer.
Apr 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
The middle panel between the freezer and refrigerator is very HOT
Sounds like the door heater has gone bad. You will need to pull off both the fridge and the freezer door panels and see which heating element has gone bad. This heater is to make sure that your doors do not ice up. But once they go bad they can be a pain to replace and repair.
Jan 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Side of refrigerator getting really hot from top to bottom on freezer side about 1 inch from the door back. Also where the two doors meet in the middle, really hot. What can I do?
The unit has a auto defrost feature. Every six to eight hours these heaters come on to melt ice build up.The cabinet will feel warm to the touch during this cycle.If it is always hot, I suspect a stuck defrost thermostat
Nov 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Outside door seams are hot to touch
This is because the mullion heaters are on. This is a system designed to dry up sweating that occurs on the outside of the box in high humidity. Check to see that all the door seals are tight.
Aug 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH is hot
i doubt it is really hot but it needs to be warm it avoids condensation around the doors
Both Freezer door and a metl strip were hot
There is a sweat control heater around the front edge of the fridge and freezer. It has a switch that will turn it off, usually by the other controls. It just wastes electricity.
Apr 23, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
687 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
