Question about Systat SigmaStat 3.0 (sigmastat 3 up)
SigmaStat 3.0 notebook - Systat SigmaStat 3.0 (sigmastat 3 up)
SigmaStat two-way repeated measurement ANOVA: error message: You have more than one measurement for a subject within a cell! I checked everything and the data are organized as usual (one subject column,...
I just had this problem. I had factor A as ***, factor B as age, and I was trying to look at my RM data. What I needed to do was separate it out, so that I was looking at factor A as ***, factor B as "session"- my repeated measure. Then I did a separate analysis with factor A as age, factor B as session.
Sep 07, 2011 | Systat SigmaPlot 9.0 (000053608314) for PC
Tip
How to enlarge your notebook batteries life
Most of our time, the capacity of our notebook battery is not enough for our work and life. If you don’t have money for Apple Macbook , Dell and HP that have acclaimed battery life of 8 hours, this few tips will help to enlarge your notebook battery life a little longer:
1. Use only the power cord that came with your notebook or other authorized replacement.
2. When you don’t use it, follow the correct maintenance for your notebook.
3. Don't leave it in direct sunlight, areas where it will be exposed to extreme temperatures such as car trunks.
4. If your notebook has power management features, use it, so the system will run at lower processor speeds when enabling power management features and it will go into "sleep" mode faster when inactive.
5. Buy notebooks with internal Li-Ion batteries. Non Li-Ion batteries must be fully discharged and recharged every 2-3 weeks.
6. If you don't use your notebook for a period of time, you must fully discharge then recharge it, so the battery will last longer.
on Jan 23, 2010 | Computers & Internet
After turning on all lights flash then it shuts off
1. Power on the notebook on battery mode. when your notebook power on then check notebook CPU fan rotate or not. 2 Remove the battery then checked notebook on Ac mode only if same issue face 3. IF you are Technical person and you have knowledge to open notebook then open the notebook clean and checked in minimum hardware. 4 IF same issue face then its issue with your System Board.
Aug 20, 2011 | HP Pavilion dv6810us Turion Notebook
Hello i have hp compaq nx9020 and when i press the power button the power led turn on for 2 or 3 seconds and then died again
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 07, 2010 | Computers & Internet
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
HP G60-120US 15.6" Widescreen Laptop PC Notebook: when trying to turn the computer on, the 3 lights ...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP G60-120US Laptop
Interxn term for a two way anova in sigmastat
yes it can be solved by collecting the dna sample and do recombinant dna
Feb 10, 2009 | Systat SigmaStat 3.0
I want to fit bigger hard drive to my ibm 380ed
Hard Drive Installation Instructions:
  • 1. Turn the notebook upside-down.
  • 2. Remove the battery pack.
  • 3. Remove the 8 Phillips screws on the bottom half of the notebook.
  • 4. Turn the notebook right-side-up.
  • 5. Raise the LCD.
  • 6. Remove the top half completely off of the notebook. Remove the 3 keyboard cables from the motherboard and set the top half of the notebook aside.
  • 7. Remove the top Phillips screw from behind the LCD right hinge.
  • 8. Remove the Phillips screw that is located above the parallel port.
  • 9. Remove the CD/Floppy disk and flip it out of the way (you don't have to remove its cables).
  • 10. Slide the hard drive out of the notebook.
  • 11. Remove the bracket from the old hard drive and install it onto the new hard drive.
  • 12. Slide the new hard drive into the notebook, making sure that it is firmly connected.
  • 13. Place the CD/Floppy disk back.
  • 14. Place back the Phillips screws that were removed in STEP# 9 and STEP# 8.
  • 15. Take the top half of the notebook and place back its 3 keybaord cables to the motherboard.
  • 16. Snap the top half of the notebook down and make sure that it is firmly in place.
  • 17. Close the LCD.
  • 18. Turn the notebook upside-down.
  • 19. Place back the 8 Phillips screws that were removed in STEP# 3.
  • 20. Place the battery pack back.
  • Enjoy!
    Jan 19, 2009 | IBM ThinkPad 380ED
    How to connect 5.1 speakers to a notebook
    yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
    Jan 07, 2009 | Creative Labs Sound Blaster Live! 24-bit...
    HP 520 NOTEBOOK WITH XP DRIVERS
    i want VGA drivers for HP 520 Notebook, how i can get it???
    Nov 12, 2007 | Red Hat Enterprise Linux ES 3 Standard for...
    Systat SigmaStat 3.0 (sigmastat 3 up) Logo
    Top Systat Computers & Internet Experts
    David Payne
    David Payne
    Are you a Systat Computer and Internet Expert? Answer questions, earn points and help others
