Question about Nikon D70s Digital Camera
Pictures won't show on screen
When i take a picture it no longer shows up on the screen
  • 3 Answers
Check the CSM menu item 07 "Image Review" if OFF no images will be displayed after a shot is taken unless you press the image review button
Posted on Feb 14, 2009
    Problem Solver:
  • 9 Answers
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Posted on Feb 07, 2009
Had LG6700 8 weeks today a faded line ran down centre of screen 15 cms wide now screen won't show picture or turn on?
you can only replace lcd's not fix them, take the item back for a manufactures warranty replacement- it sounds like the lcd pixels dead or at least on its way, also a possibility the lcd controller is malfunctioning
Mar 30, 2013 | Televison & Video
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
Samsung 793S (Black) 17
On these older CRT monitors when you have that type of problem it indicated that the high voltage power supply is not putting out the right voltage to charge the picture tube. As the power supply gets weaker the time to show a picture will take longer and longer. It is not worth repairing the unit because parts will run much more than a replacement monitor.
Jul 19, 2012 | Samsung 793S 17" CRT Monitor
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Aug 04, 2011 | Computers & Internet
Blank screen when taking a picture
Yes it is. Press the DISP button on the back of your camera. This manually turns the screen on and off to save batteries.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
Please help me, i have a fuji finepix a350 camera and i won my camera to show the date inside the picture, i tryed all the options but it shows the date for 2-3 seconds on the scren and then does not shows...
You can't get date on the pictures, when viewing them on the screen og on the computer. You can print pictures with date printed on them. Press Menu/OK while viewing the picture on the camera. Select DPOF, select With date. You need to do this with every single picture you want date on. It also requires your printer to be DPOF compatible.
Feb 02, 2010 | Fuji FinePix A350 Digital Camera
Canon A75 - viewfinder shows- purple distorted picture.
Its bad ccd imager in camera and this part will be replaced.
Canon will repair Free of Cost A75 camera as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 15, 2009 | Canon PowerShot A75 Digital Camera
Screen does not show picture, distorted image
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Oct 04, 2008 | TruTech PVS12701 Portable DVD Player
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Nikon D70s Digital Camera Logo
335 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
