Question about Texas Instruments Voyage 200 Calculator
Formatar voyage 200 - Texas Instruments Voyage 200 Calculator
Voyage 200 black dots
I suspect that the screen is damaged. The liquid crystal is leaking. It could be old age or some violent shock. It may be time to replace it with a TINspire CX CAS, a Casio Class Pad 400 or the latest HP Prime
Jan 20, 2014 | Texas Instruments Voyage 200 Calculator
Voyage 200 crash
For the TI-89 Family, TI-92 Family, and Voyage 200:
  1. Try a new set of batteries (including the backup battery).
  2. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  3. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  4. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...".
Feb 27, 2013 | Texas Instruments Office Equipment &...
"Spurios Interrupt"
  1. Users of the Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  2. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore OS
    Finally, try with new set of batteries (including the backup battery).
Feb 10, 2013 | Texas Instruments Voyage 200 Calculator
Voyage 200 wont connect to computer
You will have better chance with a TI USB Silver cable. Install TI Connect 1.6x first, then plug the cable in to the IO port on calculator and the USB side on a USB port on computer.
Jan 28, 2013 | Texas Instruments Voyage 200 Calculator
Voyage 200 pixel line problem
GUEST... thank you very much.. works fine with my voyage ;)
Mar 31, 2012 | Texas Instruments Voyage 200 Calculator
How to do a reset the voyage 200
In HOME press [2nd][6] to open the (MEM)ory management.
Then press [F1] to unfold the RESET menu and select the type of reset. Use the right arrow to see what is under the three reset options.
Here is a screen capture to help you.
Jul 04, 2011 | Texas Instruments Voyage 200 Calculator
My voyage 200 Just won't turn on.
Here is the link to the TI FAQ and Knowledge Base where you will find troubleshooting information, in this article Towards the bottom of the page is the procedure that concerns your calculator. In the artcicle are links to the reinstallation of the OS.
Hope it helps.
Feb 28, 2009 | Texas Instruments Voyage 200 Calculator
Voyage 200 won't turn on
I've fixed my Voyage 200!! I fixed it using the 3rd solution listed below. I've placed them all in there in case the one I used din't work. The funny thing is the solutions listed weren't even for the Voyage 200. I mistakenly tried the wrong one, but it worked!! I've also posted some soultions listed for the Voyage 200 just incase the others don't work and the website I found these solutions can be found here. Good Luck!!
Website:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=85103&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG1C0B48595DC76138EFAD7BAC9C1E63B698A69C9FCFEA6C84DEE9934631AC138649F2CD10EBEEF5C5E390C0B8C5F215C2F3
List of solutions that worked for me:
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message. (worked for me!! Never actually said "Ram Cleared" just had a long box across the screen that filled up and POOF it was back!!)
  4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Voyage Solutions:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  4. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
Jan 28, 2009 | Texas Instruments Voyage 200 Calculator
Texas Instruments Voyage 200 Screen
If people can get new hearts, why can't your calculator get a new screen? Here is the contact information of TI product support.
Hope it helps.
Jan 19, 2009 | Texas Instruments Voyage 200 Calculator
Texas Instruments Voyage 200 Calculator Logo
77 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
