Question about Samsung LN-S4692D 46 in. LCD HDTV
SAMSUNG LE46M51BX 46 inch. lcd tv wont turn on
The standby light is on but the tv doesnt switch on. usually when i was away for a month and the tv was switched off, it would take a few hours once i turned the electricity on, for the tv to be switched on. this time it's been over 24 hours and it's still not switching on. help!
  • greeneyedval Feb 07, 2009
    this has happened to me ever since the blackouts last week in melbourne
  • Anonymous Feb 22, 2009
    2 days old and won't turn on from standby either manually which they told me to do or with remote. Told by Samsung to unplug for 45 mins. & let it reset. Nothing. Told by service repair they gave me, that's what he would do, so it is more to it. Personally he said to take it back to the store, which I am.
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 16 Answers
SOURCE: Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Posted on Mar 31, 2009
  • 304 Answers
SOURCE: samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
  • 25 Answers
SOURCE: scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Posted on Nov 30, 2009
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Samsung 46
Yes. There will be standby light ON, when you plug in the set to AC mains, if the front panel Power Switch is ON. There will ba a clik sound too. When you switch ON the set by its remote control, an other click also will be there.
Jun 07, 2012 | Samsung LN46A550 LCD TV
My 40 inch samsung tv is only 18 months old and it has literally just stopped working; no electrical power going through the system what so ever?
You can pop off the back and see if the fuses are blown....but samsung tvs are notorious for power problems.......See if its still under warranty.....
Mar 25, 2012 | Samsung LN40B550 40 in. LCD TV
Samsung LN40A550 40-INCH 1080P LCD HDTV power off/on quickly
you need to be vigilante in your efforts to have the problem repaired under warranty this is an intermittent fault and they are obligated to address the problem in a timely manner, contact management, contact the manufacturer. put the wore in to warranty it works good luck
Jan 31, 2010 | Samsung LN40A550 LCD TV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No picture
try chicking the horizontal section or vedio section...
Jan 28, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
649 people viewed this question
Henry  Thomas
Henry Thomas
