Question about Welch Allyn - Spot Vital Signs Monitor NIBP/Temperature WA420TB-E1
Our machine has error code E38 and will not charge, what does this mean?
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Sep 16, 2015 | Washing Machines
E38 error code
Hi Friend, thank you for allowing me to assist you!
Typically an error code E38 on your Frigidaire washer could mean a few things:
First see if the air trap is clogged. If it is, that is probably the most likely issue.
If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
To make sure it is not a false error code, reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best regards! - Z
Jul 20, 2014 | Frigidaire Washing Machines
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Mar 24, 2014 | Billcon N-131 Money Counter
I have a Frigidaire Affinity front load washer Model ATF7000ES0 and am getting error code E38
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
Apr 15, 2013 | Frigidaire Affinity ATF7000E Front Load...
What does code f1 mean
Hello
Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
C 2101 on bizhub c451
this error code means there is charge cleaner malfunction. during the backword movement if the cleaner the home sensor was not actuated after a predetermined amount of time. to reset the error code leave the machine on and open then close the front door if the charge cleaner motor has been disabled in service mode this error code will happen at start up
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Error code on a T-A TA215Z copier.
C5 is a Main Charge Wire Error. Either the main charge wire is broken or the plastic blocks are arching out.
Open the front door, and look for a gray handle that will slide out towards you. This is usually located above the drum.
The main charge wire is a very very thin wire that charges the drum in the copy process. If the wire is broken, no copies can be made. To make sure that this is the problem, leave the charge stick out, and close the front door and let the machine warm up. If it does, then you have located the problem.
If it still show a C5 error, the the problem is in the Transfer Charge coronas which is located under the drum.
Let me know what happens, and I can try to help you further.
Good luck.
Mac
Mar 16, 2008 | Office Equipment & Supplies
Welch Allyn - Spot Vital Signs Monitor NIBP/Temperature WA420TB-E1 Logo
49 people viewed this question
Top Welch Allyn Health & Beauty Experts
Tom Chichester
denochearingaid
denochearingaid
adrohearingaid
adrohearingaid
Are you a Welch Allyn Health and Beauty Expert? Answer questions, earn points and help others
