Question about Maytag Neptune MDE5500AY Electric Dryer
When i open the door light does not come on
Can i replace this my self or does a repair man have to do it?
  • 350 Answers
I'm assuming this is a dryer and if the dryer still stops when you open the door then the switch to stop the dryer and light the light is probably working so it sounds like the bulb burn't out.
Locate the bulb and remove it. It's probably only a couple of screws and a bulb that you push in and twist to remove. Inspect the bulb and if it looks bad call around for a replacement and remember to take the old bulb with you to verify the replacement is the same.
Hope this was helpful.
Good Luck!
Posted on Jan 21, 2009
I have a Frigidaire Dryer Model FER341ACO.....that will not start....I am unable to find any information on troubleshooting the issue.....
The door operates a safety switch so it stops with the door open , this often goes open circuit , if this checks out ok , best to call a service repair man.
Jul 10, 2015 | Frigidaire Dryers
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
I have a whirlpool model number GEQ9800PW1, the serial number is MS2024548. I just noticed tonight that when I opened the door the light didn't come on, I thought well I can live with that, but when I...
door switch: http://www.partselect.com/dryer+replace-door-switch+repair.htm
to open dryer: http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
can buy at a appliance repair/service shop, online or eBay. Good Luck Tim
Nov 29, 2010 | Whirlpool Dryers
Fails to turn off, and now no heat.
Runs and never stops:
In all probability this may well be the timer motor has quit,and thus the timer needs replacing right? Maybe, but you need to first check to see if your dryer has a moisture sensing system, If the sensor board contacts get corroded or goes caput, then the dryer wont know when to advance and shut off in newer models!
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Sep 12, 2009 | Dryers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
My dryer is about 10 years old. I had a belt replaced last year and currently it has stopped working. When I open the door the light comes on but when I press the start button I get nothing. My husband...
102610f.jpgHave you checked the Thermal fuse?It is also a good idea to check your door switch and the wires coming from it because they sometimes hang into the tub and wear out.
Jul 22, 2008 | Whirlpool Dryers
Dryer suddenly stopped - F&P ED56 Autosensing Dryer
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Sep 09, 2007 | GE DVL223GB Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
256 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
