Question about Hunter 23534 Oceanus Graphite Ceiling Fan
WHERE CAN I GET A BALLAST FOR OUR FAN - Hunter 23534 Oceanus Graphite Ceiling Fan
How do i remove a ballast from a ceiling fan
Ceiling fans do not typically have a ballast only flourscent light fixtures have a ballast. There could be a few problems.
Verify the plastic plug is plugged in,, verify by removing the light fixture and make sure it is fully seated. Next check the pull chain switch these will fail if they are used alot to turn the light on and off. If you have a seperate wall switch check for power at switch and at fan with a meter.
Sep 08, 2012 | Hampton Bay 24002 Ceiling Fan
Were are both of the cooling fans located on my Hatichi Ultravision Dlp tv?
Some have cooling fan Located under the light Engine, Lamp Fan,Ballast Fan.on the Ballast Board.
Aug 17, 2011 | Hitachi 50V720 Television
New lamp and still blinking lamp light.fan running fast and pulsing turns on and off and temp light blinks when using remote no light from lamp
MIne did the same thing, thought it was the lamp, bought a new one....still did it, figured it wasn't the ballast because the light came on for about 3-5 seconds - was told the ballast was bad, the ballast supplies high power to the lamp - if it is weak, it will not supply enough power and lamp shuts down. Bought a new ballast on Amazon for $62.00 - problem solved. I also tried a cooling fan - NOT the problem, was the ballast
Feb 16, 2011 | Samsung HL-R6167W 61" HDTV
We get a message on the screen that says Check Fan 2 and the manual does not tell how to do that . My husband is very handy and probably can do it if we were given any instructions at all.
I think Fan 2 is the DMD fan Located behind DMd Moduel its the Board mounted in the Middle Just CK all of the Fans, Lamp Fan,Ballast Fan which is a tiny fan on the Ballast board.
When sitting behind the TV on the right hand side is the Lamp Fan Lamp and Ballast board in the Middle is the DM Aluimmium looking box and on the Left handside is the power supply board.
I hope this will help you .Encompass Parts Distribution List this Model and Parts Visit their website
Samsung Parts.com 1-800-627-4368 Let me know if you need any more help.
Nov 14, 2010 | Samsung HLN5065W 50" Rear Projection...
NEC LT265 PROJECTOR WILL POWER UP BUT WILL NOT COME ON. BULB IS A YEAR OLD. WAS PLAYING A MOVIE WHEN IT WENT OFF AND WILL NOT COME BACK ON. NOR WIL THE FAN RUN. POSSIBLE BALLAST?
It cannot be a ballast because the fan would not run off a ballast. Sounds like a serious hardware failure, I would check with the manufacturer.
Mar 10, 2010 | NEC LT265 Multimedia Projector
I have a Hunter model 21241 ceiling fan with circline fluorescent light. The light module is a VEB82122 (ballast "A"). This is part of switch housing assembly part number 93563-09-000. I get a dim...
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
Aug 13, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
I need simple instructions on how to replace the ballaster for a mitsubishi wd-62525
Minor point, the correct term is 'ballast' like on a fluorescent lamp.
Unplug the unit from the wall.
Remove the filter cover (from the rear, it's on the right side of the electronics cover). Remove the electronics cover (the one on the back with the fan in the center). Remove the rear metal plate (about 25 screws). Remove the right rear support bracket to gain access to the ballast area. Remove the ballast shield. Unplug the two connectors on the ballast module. Unscrew the lamp connector (2 screws). Remove the 2 screws holding the ballast in place, they're at the closer end, near the fan. Lift the closer end of the ballast board and remove (there's a hooked lip holding the other end, no screws).
Jun 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD52725 not coming on
it is not a common problem with this set. are you able to tell the pattern of the blinks.? is it (a)1 long 1 short, or (b) 1 long 2 short, or (c) 1 long 3 short. this will let you know which fan is blocked or has failed.a=Chassis Fan (above chassis) b=Ballast or Exhaust Fan
. exhaust fan is easy to see. ballast fan is hidden between ballast and vent tunnel.c= lamp fan, this is under the lamp. you can measure the yellow wire voltage on the suspected fan, if it is more then 1 volt the fan is bad or jammedlet me know whic one and i will post the part number
Dec 26, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Tv does not power on
This is a bad fan. There are 4 fans in the tv. Any one of them can cause this. Here are the part numbers:
Lamp Fan FAN-LAMP 299P282010
DMD Fan FAN-DMD 299P283010
Ballast Fan FAN-BALLAST 299P278020
Exhaust Fan FAN-EXHAUST 299P103050
Aug 05, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Hunter 23534 Oceanus Graphite Ceiling Fan Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
