Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Wd860 display screen is showing F-09 ? and the drum is turning clock wise and anti clock wise very slowly? Can you help?
  • karl edwards Jul 07, 2007
    thanks for your comments but i bought the machine out of the paper so i dont have any paperwork for it.
  • 67 Answers
Setup error [check eeprom]. Call an engineer as you will have a 5 years parts cover
Posted on Jul 06, 2007
  • Darren Moxam
    Darren Moxam Jul 09, 2007
    in that case then it will almost certainly be cheaper to buy a NEW machine then
SOURCE:
How do i adjust the drivers side back drum brake on a 1999 dodge ram 1500
Hi most of the drum brakes that I have worked on in the past have a square adjuster on the back of the drum(some have 1 some have two)so first of all you need to jack the back wheele up off the floor(loosen wheele nuts first)then put axle stand under car,now look at the back of the drum there should be a square adjuster at the bottom if you turn it clock wise the brake shoe will start to stop the drum,when the drum stops then gently turn spanner anti clock wise untill drum just moves around freely without binding,then just check that there is not another adjuster at the top of the drum,if there is do the same as you did to the bottom adjuster, if there is not another adjuster then the job is done.(when you have wheele off also check the drum for eney brake fluied leeks).
I hope this was some help all the best.
Mar 08, 2015 | Dodge Ram 1500 Cars & Trucks
I cannot get my Candy GOFS262 on a 'SPIN ONLY' cycle? It just fills with water, drains and spins? I only want to spin some already wet laundry - HELP please?
this is a problem with these machine turn the selector anti clock wise slowly to spin as the contacts on the selector wear out or try clock wise but slowly some times this works
Jan 31, 2015 | Candy Washing Machines
How many round will open anti clock wise of air screw in passion pro model 2010
Standard procedure is 2 and half turn anti-clock wise i.e. if the air screw is screwed in but care has to been taken when screwing it in do it very slowly and with less efforts so as not to damage the point.
Best to adjust this air-fuel mixture is to let the bike's engine reach normal running temperature than you adjust ...you can go a little plus or minus depends on many other factors.
Valve clearance too have to be checked and set according to the manufacturers specs. Hope this helps!
Nov 05, 2014 | 2010 Hero Honda Passion Pro
How do I reset the truck to start after the anti theft lock has been activated?
Insert correct key in to Drivers door and turn clock wise then turn counter clock wise unlocking and resetting security system. This usually dose the trick HUCK.
May 06, 2017 | Chevrolet Cars & Trucks
Epc light + brake lights on constantly
replace brake light S.W ,remove out by press in and turn anti clock wise ,then pull out ,fix new S.w pull outer the adjuster first then press in then new s.w till adjust then turn clock wise
Nov 06, 2013 | Skoda Fabia Cars & Trucks
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
137 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
