Question about Cell Phones
My bluetrek bluetooth deleted itself off my phone
I bought a bluetrek skin bluetooth headset and i have an LG Chocolate lg800 phone i searched for bluetooth devices on my phone and had no problem hooking up my bluetooth but a week later it deleted itself from bluetooth devices and now i cannot activate it again i try to search for devices and it instantly says no device found how do i fix this or can i fix this?
Find my blackberry when its off
Posted on Apr 16, 2009
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
Havn't used bluetrek S2 in a while. How do I link it to my phone-can't find manual.
go to the menu on your phone select manage connections turn on bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Jun 07, 2010 | Motorola Mobility Bluetooth Hands Free...
Hiw do I disconnect my bluetrek from my phone
Just turn your headset off, by holding the Talk button for some 5 seconds. Besides, if your phone's bluetooth radio won't be used for other functions (like e.g. file transfer), turn it off too, in order to save some battery juice.
Just my 2 cents.. Carlos
May 09, 2010 | BlueTrek G2 Consumer Headset
How to connect the bluetooth headset to mobile phone? how should we start it? how to connect?
First look for the connections option in your phone. Turn it on, it should have an option for searching for bluetooth devices, at this point you should turn on your bluetooth device so it could be found. It should be fairly easy to follow the connection setup in your phone. If not I suggest you read the quick start guide that came with your phone or do an Internet search for the manual for your phone.
Mar 28, 2010 | BlueTrek G2 Consumer Headset
I can't connect my hbm-210 bluetooth to my
Go into your phone and under your bluetooth settings delete your headset profile. You can now just go through the pairing procedure again and your phone should find the headset and you can click yes pair with this device(headset) and just finnish you pairing. Also make sure you didn't turn your bluetooth power off on your phone by accident.
Jan 28, 2010 | LG Cell Phones
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
Oooo passkey is not working
Is your Blackberry,s bluetooth 'visable to all'. (a selectable function)
Aug 20, 2009 | BlueTrek G2 Consumer Headset
Bluetooth problem...
I'm not sure about LGs, but I know you can't set a Motorola to be permanently visable, it hides itself after 1 min. LGs might do something similar. Either way, you only need it to be visible to pair it. Once it is paired with the headset or "bluetooth earphone", the phone doesn't need to be visable to connect to paired devices. To pair a bluetooth headset, refer to the manual of the headset on how to put it in "Pairing Mode", then go on the phone to add a new device with bluetooth, and find the headset. There will probably be a code you need to input on the phone. It should also be in the manual of the headset.
Dec 04, 2007 | LG Chocolate Clamshell VX8600 Cellular...
My lg hbm-730 headset is stuck in pairing mode
I have the exact same problem. I suggest you flush the LG piece of **** down the toilet, and never purchase from LG or bluetooth again.
Sep 09, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Cell Phones Logo
120 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
