Question about Keurig B60 Coffee Maker
How can I drain the holding tank of water from my kerig
  • 1,511 Answers
Turn upside down over the sink for 5 min.
Posted on Feb 06, 2014
Water holding tank in an RV
May be some toilet paper build up that is blocking the drain. Put some water and some additive along with a bag of ice in the holding tank and drive around town. This will break up the sludge and clean the sensors. Then try to drain it again...
Jul 25, 2017 | RVs
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 | RVs
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 | RVs
Keystone Raptor 3110TT 2007 and fresh water holding tank. What size PEX cap do I need to prevent water from running out of my drain. Can't fill up water holding tank.
The water tank drain should have a shut off valve to prevent water leak. I wouldn't cap it, you should want to drain water tank on occasion.
Mar 21, 2017 | RVs
There is a valve underneath the coach, same area as the back passenger wheel. Periodically I notice water dripping from it, why?
If it is a big valve it is your sewer tank drain valve. There is two valves. One is the Black water drain and the other is the gray water drain. the black water drain comes from the toilet holding tank, and the gray water valve drains the shower and sink holding tank.
Jan 18, 2015 | RVs
Back grey water tank will not drain
There is usually a drain valve for each tank could be under trailer in middle some where
Sep 09, 2014 | Keystone 2013 Alpine 3720FB
How do you drain the fresh water tank without having to pump it all out into the grey water holding tank?
Find where the fresh water tank fill is located. Directly below that under the coach you should see a single low point drain for the fresh water tank. It may have a cap on it but it may also have a valve at the location of the drain hose to the tank fitting.
Jul 01, 2014 | Dutchmen 2011 Fourwinds Breeze 190RB
Draining holding tank on 2012 v3600 Voltage
Fresh water holding tank will have a single 1/2" line hanging down under the trailer. It will have either a cap or a valve. To drain open the valve or remove the cap. For gray water and black water you must be connected to an approved dump site with an approved RV sewer line. Open the 3" valve first and allow the black tank to drain then open the 1-1/2" valve to drain the gray water. This will flush the sewer line as well.
May 04, 2014 | Dutchmen 2012 Voltage V3600
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
How do you descale the kerig?
You must buy a descaling liquid at any big grocery chain. Then add the right amount of cleaner with water in the tank.Set the machine thru a descaling mode or just run a few cycles without coffee thru the machine. Then i would just run clean water thru a few cycles just to clean any residue left from the cleaner. If your using any type of bottled water when you make coffee, I would just use tap water, this will slow down the scaling process.
good luck
Feb 25, 2011 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
43 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
