Question about Michigan Industrial Tools MIT 18-Volt Cordless Drill Battery
Need to find a battery charge pt 732751 - Michigan Industrial Tools MIT 18-Volt Cordless Drill Battery
Wiring diagram for altenator in 2005 pt cruiser
I would be checking the external regulator ( if it is not internal in the alternator ) as that will stop a charge for the battery
Jun 19, 2016 | 2005 Chrysler PT Cruiser
Replaced alt/ battery 2005 PT cruiser is good but i loose the charge and battery is dead by morning ...even after running my car !
Connect an ammeter and set to the 2 amp scale and check out the current drain with the ignition key removed. Remove a fuse one by one until the current drain goes down. That is the fuse that is connected to the power line that is responsible for the drain. Check all of the accessories, etc on that line for the draw.
In meantime till you resolve the issue just disconnect the negative battery terminal till next time you want to use the car so the battery does not drain.
Sep 15, 2015 | 2005 Chrysler PT Cruiser
2007 pt cruiser alarm goes off in cold weather
Batteries voltage fluctuates with temperature. Your battery could be discharging due to the cold to the point where the alarm doesn't see enough power to be on and ready, like in standby mode. I'd recommend getting your battery tested. You may need to charge or replace it.
Feb 20, 2015 | 2007 Chrysler PT Cruiser Touring Hatchback
Battery light still on after replacing alternator in 2001 pt cruiser
Well the battery light means the battery is not being charged, but it could be a fuseable link or computer problem. Could even be a problem with the ignition switch.
You need to know if the alt is getting a signal and has batt voltage.
Jun 25, 2012 | 2001 Chrysler PT Cruiser
Pt cruiser charging problems
The Alternator is controlled by the voltage regulator, type is located inside the Powertrain control module, you guessed it the alternator is computer controlled. You will need the dealer to look into this before you waste anymore money on parts.
Jun 16, 2012 | 2001 Chrysler PT Cruiser
My 2006 pt cruiser battery light is coming on. What does this mean?
There is a problem in the charging system. Either your battery is not holding a charge anymore, or your alternator is dead. The first thing to do is check the alternator. turn on the car and then remove the negative battery terminal. If the car shuts off immediately after disconnecting the battery then your alternator is bad and needs to be replaced. If it stays on, then your alternator is OK, you then need to remove the battery and go have it tested at your local auto parts store. Also have all the battery cables checked for corrosion as well, if they're hard and frayed then replace those as well.
Aug 03, 2011 | 2006 Chrysler PT Cruiser
I have a 2007 PT Cruiser. I replaced a dead battery in July. Same problem in Sept. Again same problem in last week in Nov. Local Midas has been wonderful, replacing 2 batteries for free thanks to...
You need to have the charging system checked. It may be overcharging the battery which would destroy any battery. I would suspect the voltage regulator is defective.
Nov 20, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
My pt cruiser will not charge the battery it has new belt new alternator and the pcm was checked and came back fine and there is power to the back of the alternator
The alternator will have power still coming through but it's the voltage regulator inside the alternator that could be bad. This is pretty much what charges and keeps the battery at charge.
Jun 05, 2010 | 2002 Chrysler PT Cruiser
01 pt wont charge replaced alternator original
you have to have power to your altinator,if you dont it will not charge,check the large wire going to your alt if you have no power trace it back, usally it will go to your starter,I hope this helps you?
Oct 03, 2009 | 2001 Chrysler PT Cruiser
2003 PT lighting issue
have the battery checked for its acidity level. the alternator might be charging it well but the battery could not store all the charge.
Oct 31, 2008 | 2003 Chrysler PT Cruiser
Michigan Industrial Tools MIT 18-Volt Cordless Drill Battery Logo
41 people viewed this question
Top Michigan Industrial Tools Drills Experts
Are you a Michigan Industrial Tools Drill Expert? Answer questions, earn points and help others
