Question about Paradigm 1000 exerpeutic heavy duty magnetic manual treadmill with
How to adjust belt on paradigm treadmill?
Belt off center
2 Suggested Answers
  • 489 Answers
SOURCE: can't find owners manual for paradigm cc-300 center channel
http://www.retrevo.com/s/Paradigm-CC-Speakers-review-manual/id/13247ci865/t/1-2/
Posted on May 30, 2009
How to adjust treadmill belt
Whet taking off the rear cover on a Trojan treadmill. there is 2 threaded bars with nuts on them. you can adjust there. be sure to adjust them same turns per side or you may have problems with imbalanced belt
Feb 26, 2015 | Exercise & Fitness
I have a summit 4500. the belt is off center to the left side and I have use all the adjustment and the belt doesn't move
Good day.
The belt can go off track for a number of reasons. If you say you've used all the adjustment and the belt doesn't move. To me this could mean that the belt either doesn't rotate or it is not moving to the center (centre), or to the right. I presume you mean it doesn't return to the center. But since you have said you've used all the adjustments, that also means that you have actually removed the plastic guards off to have done the supposed adjustments needed to make the belt track back in the center. So, here is the confusing part. Depending on which plastic guards you removed to do the supposed adjustments, normally the belt tracking bolts are at the foot of the treadmill. Stand on the treadmill, looking at the Instrument panel, the foot of the treadmill is behind you. There are two hex type adjusting bolts, one on each side. Now if the belt pulls left, you don't tension the left adjusting bolt, which would stretch the belt and make the treadmill labour worse. A belt that pulls sideways now but not when it was new, shows that the treadmill belt had been neglected. Instead, try slackening the right adjusting bolt to loosen the tension of the belt. An over tightened belt makes the motor work harder, leading to overheating and cook out, plus it also stretches the belt unnecessarily. A lose belt also means it slips at the revolving rotor (motor side) each time you impact the belt with your feet as you run or jog, therefore it means that the slippage will cause the rotor or the belt to wear out. To check on the correct tightness, lift one side of the belt at the center of the platform. It should raise no more that 2 and half inches. if it is less, it is too tight, if it is more, it is too slack. Either way, it is for you to experiments because you could be a six foot five and weight a tonne or you could be a four foot two and weight like a butterfly. Each person is different. Most treadmills are adjusted for up to five foot ten and for those that are taller or bigger, there are treadmills designed for them too. As you know, there are treadmills for all walks of life, small ones, medium ones and large ones, all designed for the appropriate weight ratio in mind. You can't use a small treadmill if you're six foot two and weight 14 stones (90 kg). There are treadmills to accommodate larger people. Most belt failures are the result of... like I said above, a number of reasons. One of them is the failure to maintain a treadmill. Lift the belt and place the palm of your hand on the metal platform (where the belt glides on) and feel if it is sticky, hard to slide the palm of your hand, or feels dry. If any of thei si evident, then your treadmill od labouring and that means the result of the belt running to one side is because it has been stretched as the motor laboriously and continuously been trying to keep going. I have a Stream treadmill and every month of continuous usage, I lubricate the underside of the belt with a quality silicone lubricant, in spray form. I never spray it directly underside, especially if I have carpeted floor, but if you have lino or polished floorboards, I suggest you don't spray it at all because it stains carpets and makes lino and floorboards slippery. Instead, use a lint free cloth. Go outside, spray the lubricant on the cloth to just soak one side, then shape the cloth into a ball, return inside and lift the belt at the center and apply the wet site of the cloth on the platform, not under the belt. Spread the lubricant evenly across the center of the platform but not towards the rollers, just the center. Then run the treadmill a little. Stop it and reapply it again. Repeat the process a third time, then run it again. Then stop it and lift the belt. With the palm of your hand, see if you can feel any moisture or a slippery feel on the platform. If it feels slippery, then the belt is lubricated properly. Do this only every month of daily use. The lubricating of the platform is almost very little. never over lubricate or you'll soon see that excess lubrication stains the machine. You can hear it when the belt runs dry. A belt that is adjusted and lubricated properly runs almost silent, but a dried out belt sounds raspy.
Oct 07, 2014 | Nordic Track NordicTrack Treadmill, A2550
Why is my proform 5.0 crosstrainer is slipping
if your walking belt is slipping it has loosened up. there are two adjustment bolts on the end of the treadmill. one on either side. these are allen heads. tighten clockwise to remove the slack. first start with treadmill running at 2 mph. tighten both one full turn. let belt adjust. check the centering of the belt. whichever side it is closer to tighten that side about a half turn. let belt adjust after each adjustment for a min.once belt is centered and if it still slips tighten both bolt evenly
Aug 30, 2014 | Exercise & Fitness
I have a life fitness next generation treadmill and the belt has slipped all the way over to the right hand side and is unusuable. How can I fix?
Belt adjustments are on the back of the machine on either side on the rails. Loosen both off first to slide belt over towards center. Then tighten slightly. Run treadmill on lowest speed and adjust from side to side until belt stays centered. After it seems to stay centered run treadmill on high to see if it stays centered and make small adjustment until it does
Jul 09, 2014 | Exercise & Fitness
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
The treadmill belt is moving to one side making it difficult to walk on. it is tearing the belt. how do we fix this problem?
check in the manual for adjustments.
If the adjustment cannot center the belt the a bearing may be worn beyond specs.
Jan 08, 2011 | Treadmill Doctor Proform J6 Treadmill Rear...
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Jan 13, 2009 | Exercise & Fitness
Paradigm 1000 exerpeutic heavy duty magnetic manual treadmill with Logo
21 people viewed this question
Top Paradigm Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Paradigm Exercise and Fitnes Expert? Answer questions, earn points and help others
