Question about Sony VAIO® VGC-LS37E PC Desktop
The LCD does goes dark after power on
When I power on the computer the the LCD screen power on and after a couple of seconds goes dark. The computer and the programs are working normal, its only the LCD screen that goes dark. The same thing happens when I switch the LCD monitor power switch on/off - the LCD comes on for a few seconds and then turns dark.
I was told that it was the inverter, which I replaced but the problem still persists.
Looking for advice to find a fix to this problem. Thank you.
  • cancer45 Jan 22, 2009
    Thanks ehsan, but its not OK. The problem is that the LCD stays on for a few seconds and then turns black. If I work the monitor power button on/off the lcd will come on again for another two seconds and turn black. Simply put the LCD display is on for a couple of seconds and then goes black. Like I said replaced the inverter, problem still persists.
  • 112 Answers
You mean few second the monitor goes in black. then its come. if it happen, it is ok
Posted on Jan 22, 2009
  • ehsan amin
    ehsan amin Jan 22, 2009
    either you can check the lcd monitor flyback or capacitor, power register or ic, soldering this things.
    Hope it will work.
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
When i turned on my monitor it stays on for a couple of seconds and goes blank (dark screen). But also has error message stating no DVI input?
here the solution to ur question.. made simple its from HP..
http://tinyurl.com/3xt5wwb
let me know if this was helpful regards, guru
Apr 24, 2010 | HP 2009M Monitor
Screens goes dark after 3 seconds
Your power supply probably has a blow electrolytic cap on it.
You need to pull the power supply board out and have someone replace the electrolytic caps on it. Believe me....if the one for the brightness is bad...they are all suspect!
Caps are cheap...but knowing how to open the monitor and do the soldering is the part that takes some skill and may be costly.
Good luck and be careful.
Mar 10, 2010 | ViewSonic VX1935wm LCD Monitor
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
Viewsonic VE170 dislay problem
Your LCD inverter is giving up. You can either buy a new inverter but its a bit expensive
http://www.lcdpart.com/Products/cpc1151r0015.html,
or you can have it fixed by some electronic expert.
Nov 19, 2008 | ViewSonic VE170 (Beige) 17" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Sony VAIO® VGC-LS37E PC Desktop Logo
471 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
