Question about Yamaha Audio Players & Recorders
My HTR 5460 won't stay on
It first stopped getting any sound from all other equipment connected, phone, CD, etc, but the tuner worked fine, did not used for months after that and now when I turn it on in a second turns itself off. I looked inside but don't see anything or even smell. Anyone have ideas? All capacitors seem OK, visually at least.
    Genius:
  • Yamaha Master
  • 1,054 Answers
Try pressing power while holding the 'fm/am' and 'input mode' buttons. This will tell you what part of the circuit is making it shut down. It should show something like I PROTECT, PS PROTECT, etc.
Posted on Jan 10, 2013
  • 8 more comments
  • kay_c2
    kay_c2 Jan 10, 2013
    Thank you, I did and stays on, says "I ANALOG BIPASS", Sleep is flashing in the right corner, is that the problem? if that's the case, how do I cancel the sleep command?Thanks
  • Steve K Jan 10, 2013
    turn it on normally, and let it turn itself off. Then do the button press procedure and see what it says. It should show some kind of protect statement.
  • kay_c2
    kay_c2 Jan 10, 2013
    Thank you! What I get, while still holding the buttons is although did it several times and the numbers change either 020, 021, 022, but not necessarily in that order, and then goes to . the "sleep" red flashing still there, and basically nothing responds to either remote or input changes.
    should have some letters in front of the numbers: ps,i, dc,?
  • kay_c2
    kay_c2 Jan 10, 2013
    I located the manual and reset to "factory set" with remote, I them turned the unit off and on again, this time it stay on and brings me back to original problem, I do have sound from Tuner but not from CD, Aux etc. Any ideas? Also when I change the imputs at some time it turns the unit off, has happened at random settings, but have nothing connected to those settings...
  • kay_c2
    kay_c2 Jan 10, 2013
    The letters PS were before PORT... although it's on now, the "sleep" has been removed after resetting, but no sound from aux et all. Thank you for your patience Steve K
    If it's saying ps prot, there's a problem in the power supply. One of the voltages is out of tolerance. This will have to be repaired before the unit is functional again. These units have a history of bad +/-12v regulators
  • kay_c2
    kay_c2 Jan 10, 2013
    Thank you, anything I can test? Worth even try to find a service place? and do you think that could be the reason only the tuner gets sound?
    Not sure about the tuner having sound only. Could be worth servicing. Most places should charge an upfront fee to troubleshoot it and give you a repair estimate. That fee is usually not too big.
  • kay_c2
    kay_c2 Jan 10, 2013
    Thank you, very much
HDTV GURU
  • 261 Answers
SOURCE: No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
Posted on Feb 02, 2008
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
SOURCE: my yamaha htr 6050
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
SOURCE: Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Dec 31, 2008
  • 336 Answers
SOURCE: turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Posted on Jan 10, 2009
Yamaha receiver HTR-3064 turn on but go to protection mode no sound
Htr-3064 reset power on - Fixya
www.fixya.com/support/t22761844-htr_3064_reset_power
Jan 8, 2014 - htr-3064 reset power on My Yamaha HTR-3064 will not turn on at all. ... 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) ... Not sure if I needed to unplug everything, but I was about to .... How do I turn ofprotection mode on my optimus sta 3200 receiver digital No sound.
Turns on but no sound - Fixya
Yamaha HTR-5460 Repair Brief.mpg - YouTube? 15:04https://www.youtube.com/watch?v=keaq2F4LrU4Feb 5, 2011 - Uploaded by Mark ZachariasThe Multimeter Junkie fixes an HTR-5460 with protectionproblems. ... Yamaha RX-V459DAB - Not powering ...Missing: 3064Yamaha HTR-5640 AV-Recei
Dec 21, 2015 | Yamaha Audio Players & Recorders
Won't stay on
You're best bet would be to buy compressed air and blow out all dust and dirt that has made its way inside the receiver. If dust is clogging the fans it will overhead and shut itself off.
Mar 14, 2013 | Yamaha Natural Sound Htr-5660 6.1 Channel...
Sound won't come on with the tuner
Hello
There ar two possibilites for thif fault, and both are related with its tuner circuit board. Either the tuner section do not get proper voltage to function, no tuning will be done or if the varactor diode that helps electronic tuning has got damaged. In both cases, no tunig will be done.
Feb 08, 2012 | Harman Kardon Audio Players & Recorders
Sony bravia tv connected to yamaha receiver htr6230 - sound was fine but now no sound - only if receiver is set to tuner - can hear radiostations - suggestions?
Hello
The input selection done with the amp is not correct. It is now confugured to receive radio. just select input to AUX. Just pre 'amp' and then press 'input' repeteadly to select 'aux'.
Jan 05, 2012 | Yamaha HTR-6130 Receiver
I have the Yamaha HTR-5940 and it has worked fine for years. Today turned on and there is no sound for the TV. Sound works fine for DVD, and radio. I have tried everything except toss it out the window....
did you connect the cables correctly most probably to get sounds out of a tv it should connected to the 3.5mm headphone jack.
you would need a Rca to 3.5mm cable for this
Oct 20, 2017 | Yamaha HTR-5940 Receiver
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
I am trying to connect a Kenwood CD Player to the Denon amp. I am using normal av cable and connecting the output from the CD player to the ''CD'' jack of the Denon amp (no 2). I am not able to get the...
I agree with this answer:try to connect the CD Player output to the working input on the Denon Amp( say tuner remove it temporarily).
try if it works, then you have a good CD player
if not check if there is volume available on CD player , turn it a little bit higher, using remote control
check if the CD is reading the disk
check also the connector you are using
check if there is a known working CD audio inside the player
if still having problems state the model of your CD player
hope this helps, thanks for using Fixya!
Aug 22, 2009 | Kenwood Audio Players & Recorders
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
598 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
