Question about Home
The hinges on my mailbox are creaking. Do I have to buy new hinges to make it stop?
    Guru:
  • 269 Answers
The best way to deal with any kind of creaky hinge is to lubricate it with something like WD40 or vegetable oil. There is no need to replace the hinges unless they are rusty and crumbling.
Posted on Jan 10, 2013
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
Frig door creaks when opening
Most likely the nylon bushings have worn out on the hinges. Get your fridge model number and call your local applience parts house. It's not very difficult to dp the repair yourself. Lots of YouTube videos explain the process.
Jan 25, 2015 | Samsung Refrigerators
Ford ka creaking on drivers side when driving over bumps in road or turning
Is this a suspension creak, or a door creak?
Components which you haven't had changed are:
bottom suspension arms
Anti roll bar links
Also lubricate your door lock mechanism, hinges and window rubbers as these can cause creaks from time to time.
Nov 13, 2012 | Cars & Trucks
I have a 2003 GMC Envoy when you open the drivers side door it makes a loud creeking noise.. it has been greased and we have used WD40 still creaks.. any suggestions would be great.
try using engine oil.put oil in a little can oiler.oil the door hinges pins and bushings.if it still sqeek.door hinge need adjustment.or the door hinge pin and bushing need replacing.
Nov 17, 2009 | GMC Envoy Cars & Trucks
When I open the drivers side door the hinge pops
oil hinges.check that door & front fender aren't rubbing.
Sep 23, 2009 | 2002 Saturn SC
Creaking noises
THE DOOR HINGE CAMS ARE PROBABLY WORN
Aug 11, 2009 | Viking DDSB483 Side by Side Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Should the door creaks
I'd say you're right that the damage is causing the problem when the material expands.
This will eventually wear away the material and could lead to other problems unless you lubricate the tight spot regularly.
As much trouble as it is, I think returning it will mean less trouble than you may face otherwise.
Dec 30, 2008 | Panasonic Microwave Ovens
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
Home Logo
47 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
