Question about Samsung HLN617W 61" Rear Projection HDTV
How do I test the bulb?
How do I test the bulb. No picture. Can anyone help me with some trouble shooting with no picture. Fans work, I can hear the click as if attempting to start the bulb and nothing. It does this three times and then shuts off.
  • john hrouda Jul 03, 2007
    It is not shattered!
    What else could it be?
  • john hrouda Jul 18, 2007
    It was the ballast board.
    I spent an extra $150 on another bulb first.
  • 41 Answers
Pull the bulb housing out of the side of the unit and look into the bulb, you will see that it has shattered into pieces inside. Right or left side of unit is an access door with a few screws, loosen and remove the housing holding the bulb. matelectronics carries bulbs.
Posted on Jul 03, 2007
Cooling fans dont work
If the fans don't turn when you first put power to the system, most likely the fans need to be replaced.
Sep 13, 2014 | Dell (6F858) Cooling Fan
Remote Not Working
This is tough to trouble shoot . IT might be the control or the controller. Take the remote to home depot and see if they have any fans that it works on that you can test it on. If it is the controller in the fan then you have to take the fan down and remove the controller.
Feb 16, 2013 | Hampton Bay Dryers
99 grand caravan- one brake light works, the other doesnt. checked fuses, checked bulb, both are fine.
Get a test light and check for power. If you got power check the ground, and the contacts, if not follow the hot wire back to the brake switch to locate the short.
Dec 25, 2017 | 1999 Dodge Grand Caravan
Running light problem on chevy express 3500 box van
Vehicle electric trouble shooting is the worst. Some of the problems you described the bulbs may have multiple filiments with only some burned out. It may sound silly but change the bulbs. Get a couple of new bulbs and try them in the different spots. Time, road vibrations and spring pressure causes the contacts on the bulbs to wear until they get a poor connection then you get a little arcing that build up a residue and a bulb that test good doesn't work.
Your on the right track with the ground wire. Try a test lamp with a good gound connection and test the different sockets, if your test light works but your bulb doesn't you have a ground fault. If neither work check the switch and fuse before you start tracing the wiring. These are just general trouble shooting tips It's very hard to trouble shoot electrical problems sight unseen.
Jun 13, 2010 | 2002 Chevrolet Express
No picture or sound
i think the light u see is the standby indicator diode. take your tv to w/shop, the technician will know how to test the following
tube so called bulb using a different mother board card, and also test the mother board using a different tube ( tv bulb)
test the power supply out put 95 volts to the line tranaformer which will give you different voltages 5, 12 and so on.
the isolation methode will help us trouble shoot the problem, we should not be rigid on one part only.
okay
9
Jan 05, 2010 | Panasonic Televison & Video
Cooling fan's dont come on at all, fans work when hardwired. Relay's test good, Thermal sender replaced. I'am out of posibilties at this point with trouble shooting. Please help!
The fans will not come on until 225 degrees. Be sure you have the correct relay. The fans should come on when the ac is running.
Jun 15, 2009 | 1998 Oldsmobile Silhouette
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Light blows when turned on
I had the same issue. Electrician pointed out my bulb was not 120v like it needs but 12v-hence the problem.....
Feb 03, 2008 | Minka Cirque Brushed Nickel- MinkaAire...
NO PICTURE
The bulb is bad, replace it, you cannot test the bulb. You can test the inverter circuit, but you will need a service manual and the knowledge on how to work on and trouble shoot solid state printed circuit boards. Good Luck
Jul 03, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
