Question about Laser Jet P3005d Printer
I'M GETTING A 59.50 ERROR ON HP LASERJET P3005d. HELP
Can anone help with a 59.50 error on the hp laserjet?
  • 1 more comment
  • antim_chordi Apr 20, 2009
    59.50 error
  • ghulamabas Feb 22, 2010
    Not initialize main motor
    ghulamabas@hotmail.com
  • arfan_mian Feb 22, 2010
    i am faceing 59.50 error in HP-p3005N what is solution
    Sniper:
  • 121 Answers
59.50 indicates a main motor failure either the motor is bad or something is stopping it from turning. can be as simple as a bad toner.
turn the machine on and listen for the motor noise if you don't hear it turn the machine off remove the toner and turn it back on if you can hear the motor running youmay just have a bad cart.
hope this helps
Posted on Mar 06, 2009
If the error continues to come up
Go to the DIAGNOSTICS menu,
Run the Component Test for each motor
If any motor is not working check the connections to the DC Controller
If all connections are good then replace the motor.
Posted on Aug 20, 2012
SOURCE:
HP laserjet p3005d frozen on "download file now send rfu upgrade"
Need further information as there are several ways this can go, some of which are fairly complicated. Does the screen state Download firmware over USB? or Resend over parallel port?
Post the exact message and I will see if I can find you the tech document that shows the steps needed, depending on what the screen says.
Jul 01, 2014 | HP LaserJet P3005n Printer
13.20.00 rear bin error
Im a Certified HP Tech and you have a paper feed problem ..13.20 is a late feed issue... clean or replace the feed rollers ... end of story! :-)
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 02, 2014 | HP LaserJet P3005d Printer
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
Jan 02, 2014 | HP LaserJet P3005d Printer
13.20.00 jam insibe rear bin
Error 13.20.00 means that there is a paper jam at the back side of the printer, which can be cleared by opening the rear cover.
Click here for detailed instructions and diagrams for clearing paper jams in HP LaserJet P3005 Series Printer.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP LaserJet P3005d Printer
Hp laserjet p3005d 52.00 error. apprears when printer is about to pickup paper from tray 1 or tray 2
Just had the same issue. I found the Flag on the Toner Cartridge that activates the laser unit to be broken off . Had to tear everything apart to find the flag that was jammed.
Nov 26, 2010 | HP LaserJet P3005 Printer
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart and...
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
Oct 25, 2010 | HP LaserJet P3005d Printer
Where do i find the drum of the laserjet p3005d?
You need to open the front cover ot the printer.Then you are goign to see a black toner catridge wich you can pull out carefuly.After pulling out the toner turn it around and move back the protective cover and you will seee the green drum.
Oct 20, 2010 | HP LaserJet P3005d Printer
Jam inside rear bin error in p3005d printer
check the backside out-bin tray for jammed paper, or simply open and close that tray
Jan 04, 2010 | HP LaserJet P3005d Printer
Laser Jet P3005d Printer Logo
7,088 people viewed this question
Top Laser Office Equipment & Supplies Experts
Alun Cox
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
