Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Black and decker 14v with chuck issues
The chuck is stuck wide open and will not close or move..
  • David Ford
    David Ford May 11, 2010
    Is this a keyless chuck and are the jaws rusted? Please let me know and I will try to help
  • 29 Answers
There is a recall on them I believe.
Posted on Jun 21, 2009
Chuck is stuck OPEN black and decker power drill
Try beating on the side of the chuck with a rubber mallet and then try and close.
Oct 25, 2013 | Dewalt DW056 18 Volt Cordless Impact...
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
I have a Black and Decker 18 V drill .I opened the bit up to its largest opening and now cannot get it to budge. It is a keyless chuck. thanks, RW The model# iis CD180GS
I have had that same issue -- I just get a pair of channel locks and clamp onto the chuck ( not hard ) and run the drill forward -- this should close the teeth.
Dec 31, 2010 | Black & Decker 18V Cordless Drill/Driver
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Black & Decker 9.6V drill has ''stuck chuck''
put some oil in the chuck and see if you can free it up buy turning it back and forth let it set with the oil for a day or so to let the oil soak in.
Nov 06, 2009 | GPS
My chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
Sep 10, 2009 | Black & Decker Drills
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
206 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
