Question about Mitsubishi xga 1024x768 dlp projector 2000 ansi lumens xd22
Mitsubishi xd22u has specks
Screen shows speckles
Plasma Tv Turning black in areas and speckles red and green as it gets hot.
plz check if the internal cooling fan are in good working condition. avoid keeping magnetic elements..eg.speakers, very nearby.
hope this helps
Thanks for using Fixya
Jul 12, 2008 | LG MU-50PZ90C Television
I have a big screen tv and little tiny white specks are starting to come behind the screen. What is causing this?
There is a fault with the light engine.one of the chips in it is faulty .there is a you tube video showing the fix.unfortunately the chips cost around 150 pound.
Oct 19, 2014 | MITSUBISHI DIGITAL ELECTRONICS MITSUBISHI...
THERE ARE WHITE SPECKS ON THE TV. IF A PICTURE IS DARK U CAN REALLY SEE THEM. WHAT COULD THIS BE?
Hello, if it's a Mitsubishi DLP set, contact Mitsubishi, they are sending out the chip at no charge to repair the problem, but they do not include the labor. if you are handy, there is a video on how to do it, otherwise when you receive the part contact a repairman. If they know what their doing, they should be able to do it there for around $100-$135.....tks
Sep 15, 2014 | Televison & Video
I have a Sanyo PLC-XP50 projector and my words on the screen are showing up white with purple speckles, when I want them just to be white.
there are a lot of dust on the Lcd panel
3 panels (red ,blue,and green) in the Projector
purple speckles means that the dust on the Green ,
1,pick the Lcd prism from the projector
2,clean it by putting it into water,with some cleaner
3,dry it with a hair dryer
4,ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 19, 2014 | Sanyo Office Equipment & Supplies
Mitsubishi hd 1080
It sounds that the panel need replacement.
Jun 22, 2013 | Televison & Video
Specks on screen....when turned on you see specks of light on picture ..looks like from inside the tv ?
Those are referred to as hot pixels. You cannot fix them, the only cure is to replace the DLP module inside the tv, and that's one of the most expensive single parts in your tv.
Hot pixels and totally dead pixels are a common occurrence and to some extent are considered normal, but each manufacturer specifies it's own limits regarding what is acceptable in each area of the screen.
Contact Mitsubishi's service department in your country to find out what those limits are. If your tv has exceeded them then you may be offered a free repair.
Jul 28, 2011 | Mitsubishi WD-65733 65" HDTV
I have a Mitsubishi Projection Television WD-65736. It has been great, but suddenly after 2 years of use there are grey specks all over the screen when it is turned on. And now today there are bright white...
I think if you were to remove the top portion of the set and carefully vacuum the dust off the lenses on top of the crt's, that will fix your problem as it sounds like a layer of dust has settled on the optics.
Oct 23, 2010 | Mitsubishi Televison & Video
Colorful "speckles" on screen
Could be the screen burn from watching T.V. on a show and the thing burnt in (in this case the colors, yes it can burn colors.) and there's nothing you can do. The insides of the T.V.'s have plasma gases which can flow out of control.
Jan 14, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have green specks in my black areas when movement occurs. Does anyone know of a resolution of the problem?
you will need a technician service the y sustain board. the tech will connect an oscilliscope to the board and readjust the voltages on this board. when these voltages are off, like yours, you will see speckles in dark or light backgrounds....
Oct 24, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Mitsubishi xga 1024x768 dlp projector 2000 ansi lumens xd22 Logo
55 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
