Question about Karcher PSI Electric Pressure Washer
Karcher K2.97M pressure switch does switch off, not on
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
Karcher 5/11c motor runs but no pressure
Firstly make sure the pressure set valve is turned the right way, fully anticlockwise I think.(if it has one I could be thinking of the next model up) and that the lance nozzle is in the correct position not set to detergent or mid point between positions. If that is ok it is probably the switch at the bottom of the machine. If under warranty send it back karcher switches are not good.
Mar 12, 2014 | Toolbank Karcher Hd511cl Hd5/11C 110V...
No water pressure on a k 2.99
Faulty pressure switch. Karcher use terrible switches you will need a new one..
Mar 06, 2014 | Karcher Garden
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
Karcher 550m down on pressure
Sounds like the unloader valve is stuck, or it is leaking
Jul 08, 2009 | Karcher Garden
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher PSI Electric Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
