Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
Ice maker works fine. I replaced the filter, but no water comes out through the door dispenser.
Very odd solution on the GE model #GSH25JSRF SS neither the ice, crushed ice, or water would work. I primed the ice maker, and left it overnight, that worked and then, I removed the lightbulb. It all worked! Now, to the rest of the house!
Posted on Nov 05, 2011
  • 410 Answers
Another posssibilty is that the water line has frozen in the door or the reservoir has frozen inside the refrig compartment (this is real likely if youve had any vegetable freeze in the refig recently) i beleive i would try unplugging the refrig and leaving the doors open for about 30 mins to allow theses areas to warm up and then try the disp again. good luck.. peyton
Posted on Jan 22, 2009
    Problem Solver:
  • 7 Answers
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Posted on Jan 21, 2009
  • Frank Torrano Nov 05, 2011
    I fixed the ge model GSH25JSRF SS ice maker, door water and ice. By priming the ice maker inside with water and. Get this. Removing the lightbulb!
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
Water dispenser is not working.
replace the filter.
if tht dosent work replace the water valve....
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My GE ice maker is working, but the water dispenser will not dispense water. I replaced the filter and the water dispenser did work for a few days and than quit. When I take the bottom grill off and take...
The line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . WR49X10173 , is the part number for the heater for the water dispensor , to keep this from happening again . Instructions come with the part .
Mar 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser is working fine, but there is not water going to the ice maker. The ice maker is turned on. I have removed the filter and put in the bypass plug. Any suggestions?
Switch the conectors going to the inlet valve.  Then open the freezer door, hold the switch to make the freezer think its closed and push the water button.  If water comes out by the ice maker then the valve is good and your ice maker needs to be replaced. If no water comes out the inlet valve needs to be replaced
Oct 25, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
No water but ice is fine
remove the filter and reinstall , it may not have seated into the filter housing it will take a little while to fill the filter cartridge as you hold in the water paddle
you also may have a water valve problem, something in the water valve that goes to the water in the door that is not allowing the water to come through the valve
Apr 24, 2008 | Refrigerators
Water dispenser not working but ice maker does
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
585 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
