Question about Zanussi ZI918 / 12K Bottom Freezer Refrigerator
Fridge has a hot spot on back wall and freezer working ok
My fridge has a hot spot on the back wall which is causes my fridge to get warm, my freezer is working ok and recently has been defrosted, it is a ocean intergrated combo fridge/freezer, please can you help!
thanks in advance
  • 87 Answers
SOURCE: belling intergrated Fridge Freezer
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Posted on Aug 26, 2007
szwaan
  • 209 Answers
SOURCE: Has been bleeping a while, then fridge got warm, then freezer defrosted!
So the freezing element in your fridge is broken and it's beeping because it gets below a certain temperature ?
Posted on Dec 27, 2007
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
sdmc73
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
HOT SPOT IN FRONT DIVIDER BETWEEN FRIDGE AND FREEZER
Greg,
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
Freezer not working, fridge is fine.
That seem to me like it could bea simple cleaning. Dust and junk gets into the condenser. Blow that ****** out and party on. I have your models service manual on my foggy blog
Mar 05, 2012 | GE GSS25LGM Side by Side Refrigerator
My fridge clicks for 10 minutes before it cycles on
OK I believe you are having a compressor over load causing the clicking. We need someone to pull the fridge away from wall, unplug and remove the lower cover that covers the compressor, fan and condenser. Plug it back in and see if your fan is working and also feel the top of the compressor. I need to kno0w how warm or if too hot to hold your hand on top. Let me know what you find, Sea Breeze
Oct 27, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Fridge walls very warm around freezer door
that is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
Sep 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frost occuring inside the frig on the top around mechanism
J,
Frost is indicative of an air leak (which means that the door seal is messed up).
Pardon me while I jump off into a thermodynamic primer here...
All of the "cold" is made in the freezer compartment. There's a fan in there that circulates this chilled air around... Only a portion of the chilled air is directed (ducted) to the fridge (beer) section.
Here's where the nifty thermodynamic whiz-bangs happen... Hot air balloons float why? Because they're lighter than the air surrounding it! (And a hot air balloon is "attracted" [like a magnet] to the coldest spot in the atmosphere) Ya know why? Because nature abhors a vacuum. Nature is always in a struggle to balance itself. So the cold air above actually pulls the balloon into the air and tries to stabilize its' temperature and equalize it with the surrounding environment (at that equalization moment, you wouldn't wanna be in the basket... know what I mean? Crash, Boom, Bang)
By "refrigerating", we are, by nature's rules, "breaking the law". We're actually pulling (removing) heat (calories) out of the food and transferring that heat to the outside of the fridge. Nifty, huh? Instead of applying "cold", we actually are removing heat!
Ok, OK... back to your issue. Frost is only water vapor that is suspended in air... When this warm air comes in contact with a "cold" surface it condenses OUT of the warm air and clings to the colder surface... think of a glass of iced tea on the patio, you know how the glass "sweats"? Imagine that your glass of tea is 22 degrees below zero Fahrenheit and now imagine what would happen to all the warm moisture laden air surrounding it. Yep, you're right... It would sweat out on the coldest surface and then quickly freeze/frost.
Now back to the balloon thing... (and nature). .. Cold air is "heavier" (more dense) than hot air, right? So if there's a leak (think of air as a fluid) of cold air [which flows toward the floor] there MUST be a replacement, right? (The whole "nature abhoring a vacuum" thing) Cold air flows out and warm (moisture laden) air fills the vacuum. Where does this warm air go?
Yep! It goes where the balloon goes! To the coldest spot it can find! (You're good at this!) Where's the coldest spot in the fridge, you ask? Well? It's at the top left, inside the cabinet. In the very back, you'll see the damper. It's used to adjust the amount of cold air flowing into the fridge compartment. When warm air hits this (the coldest part of the fridge) it immediately condenses and frosts over. This frost builds up a wall. This wall stops air from circulating. When air stops getting to the fridge, your eggs spoil, your mayonaisse stinks and your beer isn't worth squat.
Now for the "WHY" of it all... Could be several things allowing warm air into the fridge.
First thing to check is the rubber door gasket. Make sure it's seating properly all the way around the door. If it's not, the door may be warped... try to warp it back into shape. You have to do this physically.
Second, use some "Vaseline" and rub a thin layer of it onto the door gasket (the part that seals against the frame). Not only will this help make a good air-tight seal, it'll also help keep the door gasket supple and intact for the life of the refrigerator.
Take this knowledge and prosper... (only AFTER you've rated this soltion as "FixYa", though)
SG
Apr 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
Fridge is warm, Freezer working ok
I had the same problem , you have to clean your freezer compartment out completely and take the covers off the inside back of the freezer being carefull not to break any wires, then defrost the cooling module by hand hot water towels messy job.
Make sure the cooling sensor is attached in the right spot and hasn't fallen down, it has a plastic holder it clicks into.
once clean and defrosted put back together and it will be fine...
Try not to put any frozen chip bags or peas etc right at the back of the freezer this causes the cooling system to freeze up.
How the system works it blows cold air from the freezer compartment down to the fridge to cool it and when the system freezes up no cold air to fridge ,hense the problem you are having...
If you are not confident in doing the job you can call a fisher and Paykel tech and they will charge you $150 to do the job.
Apr 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Zanussi ZI918 / 12K Bottom Freezer Refrigerator Logo
675 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
