Question about Recoton Advent Advent ADR-560 Remote Control
Seting RGB sharp alexander slim 2 - Recoton Advent Advent ADR-560 Remote Control
Schematic diagrams of Sharp Color TV 21 Alexander Pro Model No. 21V-FX300S.
Check the IC numbers used in it kit; and distinguish which company kit is used with. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | Sharp Televison & Video
Sharp 21 Alexander pro TV I want a service manual or schematic diagram.
Feb 10, 2015 | Sharp Televison & Video
Hello, I also have an RCA G32705 unit, and I have a question for you. Although the unit has Video 1 and Video 2 ports on the back, the internal menu will not allow me to activate them. The only port...
you must go on menu- set input signal and you must choose RGB or video in complex signal (1 or 2), not antenna or RF input. Coax input port is a RF input port. Your problem is only from tv menu ( input seting)
Mar 07, 2011 | Televison & Video
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
Looking for solution for Sharp Aquos LC32D41U 32 "
when it goes black then check with flashlight 2 in from screen and see if you see a picture, if so then inverter board is going out, you can google your model and inverter and find the replacement.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
How to reset psp 2000
go to system setings then go to restore default setings if you want to delete every thing on your memory stick go to system setings then go to format memory stick, HOPE IT HELPS AJ
Nov 09, 2009 | Sony PlayStation Portable (PSP) Slim...
I want to reset my psp slim...how do i do it?
Jun 24, 2009 | Sony PlayStation Portable (PSP) Slim...
Connecting pc
Did you change the input on your tv to the corresponding input that your RGB cable is connected to?
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
PS2 SLIM w/ POWER.. no OUTPUT...or No Picture
What video mode is the unit in>?
RGB or CyRyYy??
Should be RGB for your reg A/V cable
Aug 23, 2008 | Sony PlayStation 2 Slimline Console
Recoton Advent Advent ADR-560 Remote Control Logo
144 people viewed this question
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Jaime Hernandez
oodio
oodio
Level 1 Expert
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
