Question about Diehard 425 Watt Power Inverter
Lights start to blink and sound alarm - Diehard 425 Watt Power Inverter
Hazard lights flashing and alarm sounding. How do I stop these?
Every car brand and model has its procedure to stop the flashing light and alarm sounding.
But still the common procedure is Make sure boot and bonnet are closed properly.
It can also be a switch, but check your alarm by locking yourself inside the car, and then press the close button on the key 2 times repeatedly until the lock control on the door doesn't make anything. Then open the door by pushing the lever or open the hood . If the horn sounds and the lights blink your alarm is ok , if only the lights blink you should take it to dealer. You can stop the hazard lights and horn sound by pressing the unlock button on the key.
May 12, 2016 | Cars & Trucks
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Antitheft light is blinking and truck wont start
Disconnect the battery for 2 minutes to reset the alarm system then hook it back up. Sounds as if the alarms kill switch was engaged, which will prevent the car from starting.
Aug 26, 2013 | Cars & Trucks
1983 lincoln continental mark vi bill blass, "charge system" "oil presure"
The charge light will blink if the key is on and the engine is not running. So if it goes off once the engine starts all is well.
I'm not understanding the oil pressure story. Were you leaving the key switch on for some time but with the engine off, then the oil pressure light came on ?
Sep 10, 2012 | 1983 Lincoln Mark VI
97 Ford Exployer is first started, dash lights blinks on and off
sounds like an alarm system that has the horn disconnected,so when you start the vehicle it trips the alarm then resets itself after awhile .see if there is an aftermarket Alarm system under the dash and remove it!
Oct 21, 2009 | 1997 Ford Explorer AWD
1995 Nissan Maxima alarm system
Hey, I bought my 1995 Nissan Maxima GLE brand new back in July 1994 with factory installed alarm, it just doen't make any sound when you arm or disarm it with remote. The only way you can tell whether it is armed or disarmed is from the lever position of your doors and the blinking red light under the dash. Only the newer versions of Nissan/Infiniti's has the "Audio/Silent" mode button on the remote which allows you to activate/deactivate you car alarm with an audiable sound or no sound at all. No worry, there is nothing wrong with your remote or car alarm.
Jun 17, 2009 | 1995 Nissan Maxima
97 honda civic - all lights inside & hazards blinking
sounds like a short in the alarm system
usually alarms will blink all lights when the alarm goes off
need to check the system with a scanner
Nov 07, 2017 | Honda Civic Coupe
Diehard 425 Watt Power Inverter Logo
51 people viewed this question
Top Diehard Televison & Video Experts
Are you a Diehard Televison and Video Expert? Answer questions, earn points and help others
