Question about Canon LASER SHOT LBP5360 Printer
1G CHG K TNR - Canon LASER SHOT LBP5360 Printer
Set time hour day
Comdial DX-80
  • Press "Feature" "#" "*" and enter your password (default is "########").
  • Press "Show" and "0814"
  • Press "Save" and then "Show".
  • The option to change the year appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the year and then "Save" and "Next.
  • The option to change the month appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the month and then "Save" and "Next.
  • The option to change the day appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the date and then "Save" and "Next.
  • The option to change the weekday appears. Press "Next" to skip. To change, press "Chg" until you see the day you want. Press "Save" and "Next.
  • The option to change the hour appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the hour in military format and then "Save" and "Next.
  • The option to change the minutes appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the minutes and then "Save".
  • Press the "On/Off" button to exit the programming mode.
Nov 04, 2013 | Comdial Executech® II 6600E-PG Corded...
LBP 5970 --16 PREP.Y TNR
Hi!
Y toner is your yellow toner that needs to be replaced!!C is cyan,M is magenta and BK is black!!
Enjoy!!
Jan 29, 2011 | Canon Color ImageRunner LBP5970 Laser...
I bought a 99 C-V PI blown engine chg out with 97
You have a ground wire off or theres a plug maybe your over looking that needs to be plugged in
Dec 08, 2009 | 1999 Ford Crown Victoria
Have the comdial phone 7260-00 HAC and need to change the time
Timeset for
Comdial DX-80
Carl
Nov 03, 2009 | Comdial 8324S-PT Corded Phone
How do I set the time on my Comdial Edge 120
Try this:
DX-80 Time Change Instructions
Software Revision F32 and later
From the attendant station or an phone with attendant password:
1. Press Feature #0 from the telephone dialpad. You will be prompted to enter the Tenant Group
number. This is typically 1, however it can be set for Tenant Group 1-3.
2. Press Save and enter in the attendant password (default is 9999), then press Show.
3. Press the Next option until the display prompts you for the System Time. Press Show.
4. The last 2 digits of the year will be displayed. If you do not need to change the year, press Next. If
you need to change this value, press Chg, enter in two digits for the year and press Save then Next.
5. The current month setting will be displayed. If you do not need to change the month, press Next. If
you need to change this value, press Chg to cycle through the 12 months. When you reach the
appropriate setting, press Next.
6. The display will show the currently programmed day of the month. If you do not need to change the
date, press Next. If you need to change this value, press Chg, enter in two digits for the date and
7. The day of the week (Sat - Sun) will now be displayed. If you do not need to change the day, press
Next. If you need to change this value, press Chg to cycle through the days of the week. When you
reach the appropriate setting, press Next.
8. The current hour will be displayed. Press Chg and enter in two digits for the hour in military format.
Press Save and Next.
9. The display will now show the programmed minutes. If you do not need to change the minutes,
press Next. If you need to change this value, press Chg and enter in two digits for the minutes (01-
59). Press Save then Next.
10. You will be returned to the top level off System Time. To exit Attendant Administration, pres
On/Off button twice.
Software Revision F2x
From any telephone:
1. Press Feature # * and enter in your password. (Default password ########).
2. Press Show and enter 08 14.
3. Press Save then Show.
4. The option to change the Year will appear. If you do not need to change the year, press Next. If
5. The option to change the Month will appear. If you do not need to change the month, press Next. If
you need to change this value, press Chg, enter in two digits for the month and press Save then
Next.
6. The option to change the Day will appear. If you do not need to change the date, press Next. If you
need to change this value, press Chg, enter in two digits for the date and press Save then Next.
Printed in the USA Page 2 of 2
7. The option to change the Weekday will appear. If you do not need to change the weekday, press
Next. If you need to change this value, press Chg, to select the weekday, and press Next.
8. The option to change the Hour will appear. Press Chg and enter in two digits for the hour in
military format. Press Save then Next.
9. The option to change the Minutes will appear. Press Chg and enter in two digits for the minutes and
press Save.
10. Press the On/Off button to take the phone out of programming mode.
Jan 27, 2009 | Lands Phones
CHI Flat Iron GF-1001
Hello alexkuzin, searching for tech info of the Farouk CHI GF-1001 flat iron is slim to none. The HT-1
is the high side of the 120v and COM-1 is neutral. The TNR will be the thermal resistor for temp regulation. If your 'burned element' is broken anywhere but at the terminal "sorry charlie" you are SOL. The TNR is in series with the heating element and if this is 'burned element" finding a replacement will be difficult. Contact your local appliance/electronics parts store. Oh,how did you insert a 120v plug in to a 220v outlet?
Nov 08, 2008 | Health & Beauty
1993 mitsibishi eclipse G1 to G2 engine swap
turbo? if you have a 1g GST or GSX, your gonna wanna swap in a early 1g 6-bolt engine.
the optimal configuration using stock 1g/2g parts would be:
  • 6-bolt w/2g pistons. compression: 1g= 7.8:1 2g= 8.5:1
  • 1g head/intake manifold
  • 1g throttlebody
  • 2g throttlebody elbow
  • 2g exhaust manifold
  • 2g o2 housing
  • 1g 14b turbo
Oct 12, 2008 | Mitsubishi Eclipse Cars & Trucks
Canon LASER SHOT LBP5360 Printer Logo
48 people viewed this question
old marine
old marine
