Question about Epson Stylus Photo 1270 InkJet Printer
POOR PRINTING QUALITY
I am getting an over all yellowish tone on all my prints. Can it be that the ink is dry or does it need to re-set and run a color test. By the way I lost my manual and don't remember how to run a test. Is there a manual I can download and print for further reference? Thanks for your help.
My problem is solved. It was dried ink! Thanks.
Posted on Jan 22, 2009
My pictures print with a yellowish tone. I use a Brother 685CW printer
Do a print quality test and check that all your print heads are printing clean. If not, run two cleaning cycles and try the PQT again. If you don't know how please chaeck the address below.
http://support.brother.com/g/b/faqend.aspx?c=ca&lang=en&prod=dcp330c_all&faqid=faq00000259_013
If still not clear, you may need to get the power purge key code (google search for it but this one will do: https://superuser.com/questions/310973/no-black-ink-printing-for-mfc-490cw-brother-printer )
Nov 22, 2017 | Brother Office Equipment & Supplies
Canon ip4850 print quality
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
Feb 18, 2015 | Canon IP4850 Inkjet Photo Printer
Hp officejet 6500 e709n print quality poor even after replacing print head
For severe print quality/missing color issues there could be an air bubble/air gaps in the printer ink lines or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest.
For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Dec 30, 2011 | Samsung Office Equipment & Supplies
When instaling new ink carchage it won't print clearly. Is there any printing Mantainace software that can downloaded.
Clean the printhead
If your printed output is streaked or has any incorrect or missing colors, the printhead
might need to be cleaned.
This process uses ink to attempt to unclog and clean the nozzles in the printhead.
This might take a few minutes and will use one or more sheets of paper.
To clean the printhead from the control panel
1. Load letter, A4, or legal unused plain white paper into the main input tray.
2. Press Setup.
3. Press the down arrow button to highlight Tools, and then press OK.
4. Press the down arrow button to highlight Clean Printhead, and then press OK.
The product cleans the printhead.
5. Press any button to return to the Tools menu.
To clean the printhead from the Printer Toolbox
2. In the HP Solution Center, click Settings.
Work with ink cartridges 1513. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Clean Printhead.
6. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
There are two stages of cleaning. Each stage lasts about two minutes, uses one sheet
of paper, and uses an increasing amount of ink. After each stage, review the quality
of the printed page. You should only initiate the next phase of cleaning if the print
quality is poor.
If print quality still seems poor after you complete both stages of cleaning, try aligning
the printer. If print quality problems persist after cleaning and aligning, contact HP
support.
To clean the printhead from the embedded Web server
2. Click the Device Settings tab, click Device Services in the left pane, select Clean
Printheads from the drop-down list in the Print Quality section, and then click Run
Diagnostic
Good luck................Pete
Jul 15, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer does prints very lightly and poorly. I have set the printer for best quality and for darkest print. ALso, I have set it for best quality in WOrd. However, the printer does a poor job.
Depending on your printer type and name brand. It is most likely running out of ink or toner. If printer is not used often it could have a dried up jet. We need to know what make and model you have to help more.
Feb 21, 2011 | Office Equipment & Supplies
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Epson Artison 800 Poor Print Quality
it sounds like you have clogged the head if you leave it for 6 hours then the ink will dry inside the head then you have a big prob if i were you i would take it back to the shop and get a refund or a replacement one i have an epson dx4400 very good
Mar 21, 2009 | Office Equipment & Supplies
Changed both cartriges and still poor quality prints
In general, after years of use, gunk accumulates in the holder where the ink cartridges rests when not in use. Then this gunk attaches to the print head clogging it. This causes streaks across the paper and poor print quality.
Also, print heads wear out after time. Cartridges should only be refilled a few times before being replaced with new.
First. Use alcohol, and try to clean out the holder where the cartridge rests when not in use. It may be a little hard to get to. Use Q-Tips, paper towels, cotton balls, whatever works for you.
Second. Clean the print heads themselves. Using a paper towel, wet with alcohol, wipe he print heads on the cartridges gently. Also gently clean the contacts and allow them to dry.
Third. As a last resort, only if the first two suggestions don't help. Hold the print heads under hot running water for 30 seconds, then blot on a paper towel to day. Try to keep the contacts as dry as possible, if they do get wet (and they probably will), allow them to dry before re installing the cartridge.
Lastly, try new (not re-manufactured or refilled) cartridges.
Nov 14, 2008 | HP Office Equipment & Supplies
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus Photo 1270 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
