Question about Simplex 4009-9001 Nac Power Extender Panel
Low battery warning simplex 4009
How do I replace batterys in simplex 4009
What, besides battery failure , causes 4009-9201 panel battery trouble alert on 4010.
My problem turned out to be with the board and the output of the charger was too low. It needs to be about 27.5 volts. The transformer was okay but the circuit that controlled the output was bad and even with adjusting the potentiometer we could not get the charger to put out the correct voltage. The fix was a new board from Simplex. We got a deal as the tech that came out had the board on his van . Labor and parts were $1,100.00. We get a lot of spikes where we are in Arizona and suspect that a bit of a jolt from a spike or nearby lightning strike wounded the board. A surge protector can help but a hard hit will toast this board.The trouble sensor looks for a full output charge or it will show a trouble
Hope that helps
May 09, 2014 | Simplex 4009-9001 Nac Power Extender Panel
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
Gemini home alarm system shows low battery
Check your charger unit it should be 13.8 volt if not its not charging also check for a short on you passives it could also give you a low battery warning
Nov 17, 2012 | Home Security
I've just replaced the power jack on my CQ60, I've charged it overnight but still get a battery low warning on startup. I can still use the laptop for over 1 hour on battery when surfing the net,...
Are you sure it's indicating that the external battery is low? Quite often, they will warn you if the CMOS battery is nearly exhausted (these are like small watch batteries inside the case of the machine). It may simply be that this battery is nearly dead.
Jul 23, 2011 | Computers & Internet
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Erratic Low Battery Warning
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Nov 05, 2008 | Canon PowerShot A560 Digital Camera
Simplex 4009-9001 Nac Power Extender Panel Logo
37 people viewed this question
Top Simplex Home Security Experts
Lawrence Oravetz
Are you a Simplex Home Security Expert? Answer questions, earn points and help others
