How to hot swap batteries for APC SMT3000RM2U
I have a problem with 4 XR frames the UPS see's them as 1,4,2,3 instead of 1,2,3,4
well as long as the ups sees them all , im not clear why that's a problem , but anyways this is a common thing that happens when doing a hot swap battery replacement , anyway if you really want to reset them back in order then you'll need to bypass the load (or remove it) power down ups and remove its input power too then remove all four trays of battery's , wait a few minutes till the caps die off and then put trays back in the sequence you wish it to be , then repower input wait 4 it to go online (5 min) and then add back load , this should make it go back to a fresh start up , but yo'll need to do this each time you remove trays
Feb 04, 2016 | APC Computers & Internet
APC SILICON 40KW Ups.. on statrting ups it doesnt goes further to any screen display,Red ALaram LED is on(no blinking etc),. can any one guide?
apc silicon 40kw ups,1.check if input phases are complete.2.do a phase swap like changing the phase sequence and see if it will complain sequence error.3.after start-up u need to do a dc start-up,the dc bus is +360/-360vdc and after the dc bud is completed you need to press the green botten to power the inverter.if it doesnt do the dc start-up then go to the log and see what it complains about.write out the complain on the log and forward it to me.08082245266.engnr festus.
Oct 02, 2015 | APC Computers & Internet
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
APC 500 beeps all the time battery tests good
It could be over loaded or too hot. Unplug everything and see if it keeps beeping. Or you can reset the logic. to do that turn off the UPS. Unplug from the wall. Disconnect the batteries. Push the on button. The LED's may flash. This is the logic reset. Put it back together and all should be good.
Aug 16, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
I WANT TO CONNECT TWO APC UPS 700 VA UNITS TO SINGLE 24 VOLT BATTERY. BY DOING THIS MY INTENTION IS TO CHARGE THER BATTERIES RAPIDLY WHEN THE ELECTRIC SUPPLY IS RESTORED. IS IT POSSIBLE TO CONNECT TWO UPSs...
waheed70, NO!!!! NO!!! NO!!! DO NOT EVEN THINK OF DOING THAT!!! You may cause catastrophic failure to not one but both APC ups units and will void any warranty you might have!!! If you are in need of longer run time on battery back-up, then start looking into buying an "ONLINE" ups system somewhere in the 5 to 10 kva range. Check out "chloride" systems and "powervar" and "toshiba" and "ONEAC" for info about "true online" battery back-up systems. Bye for now. 12fixlouie
May 02, 2010 | APC Smart-UPS 1000VA UPS System
How do i disconnect the RBC40 battery from the APC unit???
Typically, APC's have a removable from of back cover that may or may not be held in with a few screws (sometimes they just snap into place). Almost all of them also have a simply plug in connector for easy battery swapping.
You can even try the APC website seraching for the make and model they may have some tips there for you.
Oct 29, 2009 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
APC 280 UPS problem. No A/C output when power interupted. Battery charges OK.
Have you load tested the batteries? DCV is not a good enough test for the batteries, they could still open right up under load. If the UPS is over 3 years old, I'd swap the batteries. Your power is drawing solely from the batteries on AC line loss, so if the UPS is failing when that occurs, almost certainly is the batteries.
Aug 20, 2009 | APC INTERNATIONAL BACKUPS PRO 280...
UPS keeps beeping and resetting. I've swapped battery and getting same results ()
You have a brand new set of batteries with a bad UPS. Sorry to tell you that. You might have waited too long to replace your battery. What I mean, if you battery can not fully charge up, the inverter will try and keep charging it until it burns out. Then you buy a battery and you are now stuck with it.
You need a new UPS, may I suggest you get a bigger one....I have a 800VA with your name in it for only $80.00 plus shipping.
That is cheaper then what you are going to find. Keep it in mind also that APC is no a realy quality product either. Great marketing but poor support. Trust me that BE 500 is disposable.
Jun 25, 2009 | APC 500VA BE500U Back-UPS ES...
Battery replacement
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 23, 2008 | APC Smart-UPS UPS System
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
