My laptop monitor blacks out (you can faintly see the desktop), but when you hit the toggle that makes it think you shut the lid and opened it, it turns back on. Sometimes it stays on for only a second, sometimes for hours. I notice that the more you open the lid, the longer it stays on. Very wierd!!! I recently bought a new power supply. Also, the battery is dead. I can only run the computer plugged in. It's a great computer otherwise and I hate to waste it for something that seems repairable. Any suggestions? It is a Toshiba 1805-s204 Thanks!!!
2 Other Users Have The Same Problem
Comment by pavanan, posted on May 24, 2008
thoshiba laptop satellite A75 series, monitor screen dark. but works well with external monior if attached. What is the problem
Comment by Guest, posted on May 24, 2008
laptop monitor dark
You said you can faintly see the desktop. This is the invertor board inside the LCD assembly that causes this. Again if it needs to be replaced, the invertor is fairly inexpensive,
labor isn't. The technician that ckecks out the laptop can determine what it needs. Yea, your right, it is a good laptop and it is worth fixing.
Just a heads up, if the tech says you need a new motherboard, he's lying, find another tech.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Toshiba 15.0 IN. XGA TFT ACTIVE
Email this problem
Can you Help with these Monitors problems?
Toshiba A215-S7408
