Question about HP Pavilion dv6000z Notebook
Web cam program won't open
Cannot get web cam version 1.1.3.3 Windows Xp to open.
  • Dan rogers
    Dan rogers May 11, 2010
    Do you get any errors or does anything happen? We need more information about the problem before we can find a solution.
I just bought a webcam from Logitech. Model is c 160. I am not able to install the software neither from Cd or the exe downloaded from Internet. I am using Dell laptop d530 with windows XP Prof 2 . ...
According to you your problem is installation of your web cam software or driver. So first check the system requirement of the web cam. Because this cam model required dual core or higher version of processor. If your Laptop is not a Celeron model or it is a Dual core or higher model then Remove all components of the driver you have installed from control panel & c:\ program files.
Reboot the system
Reinstall the driver by autoplay or by open the CD .
If not installed you can try to install it by update driver wizard from device manager.
Before installing driver plugged in the web cam & make sure it detected to the system.
This may solve your problem.
Jan 24, 2011 | Logitech Webcam
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Changed batters in mouse. Now doesn't work. No
1.Make sure that you have inserted both the required batteries (New batteries) into the wireless pointing device and that they are positioned in the correct direction.
2. Resync the mouse.
3.If you do not have the resync button follow the next step
4.Test the device on a different computer
If the issue continues to occur, test the mouse on a different computer in a different environment. If you can replicate the problem in a different environment, you may have a defective device. If this is the case, see the "More Information" section for information about how to contact Microsoft Supplemental Parts to obtain a replacement device.
5.Test the mouse by using the Mousinfo diagnostic tool
The Mousinfo diagnostic tool is installed together with the IntelliPoint software. If you do not have this software, you cannot open the tool.
To install the IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
6.To open the Mousinfo tool, follow these steps.
* Windows Vista or Windows 7
1. Click Start
Collapse this imageExpand this image
Start button
2. Click All Programs.
3. Click Accessories.
4. Click Run.
5. In the Open box, type mousinfo, and then click OK.
* Windows XP
1. Click Start.
2. Click Run.
3. In the Open box, type mousinfo.
4. Click OK.
6.Click the mouse buttons to check whether the button clicks are recognized as UP and DOWN commands in the tool. If the mouse buttons are not recognized, you may have a defective device. If this is the case, see the "More Information" section for information about how to contact Microsoft Supplemental Parts to obtain a replacement device. However, the best way to determine whether the device is defective or damaged is to try the device on a different computer.
7.Uninstall any conflicting mouse software
If you have any other mouse software that is installed, such as Logitech or touchpad software, that software may conflict with the IntelliMouse software. To uninstall the other software, follow the appropriate steps for your version of Windows.
8. 1.
Open Programs and Features in Control Panel. To do this, follow these steps:
1. Click Start
Start button
2. In the Start Search box, type appwiz.cpl.
3. Press ENTER.
User Account Control permission
If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
* Windows XP or earlier versions of Windows
Open Add or Remove Programs in Control Panel. To do this, follow these steps:
1. Click Start.
2. Click Run.
3. Type appwiz.cpl.
4. Click OK.
2. Find any other mouse software in this list, and follow the instructions to remove the software.
3. Restart the computer.
9.If the issue continues to occur-Remove and reinstall the IntelliPoint software
1. View the list of programs that are installed on the computer. To do this, follow the appropriate steps for your version of Windows.
1. Click Start
Start button
3. Press ENTER.
1. Click Start.
2. Click Run.
3. Type appwiz.cpl.
4. Click OK.
2. Remove Microsoft IntelliPoint. To do this, follow the appropriate steps for your version of Windows.
1. Click Microsoft IntelliPoint.
2. Click Uninstall/Change.
3. Click Yes to confirm that you want to remove the program.
* Windows XP
2. Click Add/Remove.
3. Click Finish.
4. Click OK.
4. Download and install the latest version of the IntelliPoint software. To do this, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK (http://www.microsoft.com/hardware/download/download.aspx?category=MK)
Mar 21, 2010 | Logitech 3-Button Cordless Optical Scroll...
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 20, 2009 | Creative Labs Live! Cam Notebook Pro...
No educational progams on pc
I have both Linux and Windows XP versions of the EeePCs. And the Linux version comes with some educational software. While the Windows XP version does not.
The vast majority of no webcam is because it is toggled off in the BIOS.
Enabling the EeePC Camera through the BIOS
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Jan 14, 2009 | ASUS Eee 4G Notebook
Can't install a logitec quickcam E 2500 on my mac
The Quick Cam line ever had drivers for Mac OS versions. See the specifications here: http://support.logitech.com/en_us/product/quickcam-connect-product/specs . The E2500 works with Windows XP and Vista. You may be able to use the camera in Boot Camp running one of these versions of Windows. The Quick Cam E2500 doesn't work with Windows 7 and newer Windows OS versions.
The Logitech Webcams, including the C525 and the C920, will work with a Mac directly.
I wish that I had better news for you.
Aug 16, 2017 | Logitech QuickCam Chat Personal Web Camera
Image quality wit logitech quickcam chat
Normal 0 You need to go to the manufactures site and download the XP or VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jul 29, 2008 | Logitech QuickCam Chat Personal Web Camera
Web cam drivers for model CS330
i want to download drivers for usb web cam oprating system is xp
May 15, 2008 | Intel Deluxe PC Camera CS330 Webcam
Use web cam
ihave cd but it is not sutable for xp version pls sen soultion
Dec 21, 2007 | Intel CS630 Webcam
HP Pavilion dv6000z Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
