Question about Pentax K1000 35mm SLR Camera
Film Advance Problem
I recently got a pentax k1000, the film advance works fine when there is no film in the camera (or if there is film in there and the back is open) but once I close the back the advance leaver becomes sticky, but movable though the camera makes a wierd sound. I became worried and opened up the back only to find the film loose and no longer in the take up spool. I loaded the film multiple times to see if it was a loading error, but the same thing happened.
  • ksanzo Jan 22, 2009
    I'm not entirely sure what you mean by reverse mode, but the film release button is not pushed in if that's what you mean
  • Roberta Smith
    Roberta Smith May 11, 2010
    do you have the film advance in reverse mode ?
    Robert
    Brigadier General:
  • 5,158 Answers
Admittedly the only thing i can think of is that you are inserting the roll upside down.. ensure it feeds out in all the tractor wheels
Robert
Posted on Jan 22, 2009
    Scholar:
  • 185 Answers
Ksanzo,
The take up spool is cracked at the base causing the spool to slip. The camera must be mostly disassembled to replace the spool ( if available ) . This is one of the very few weak parts in the K1000. send or take it to a camera repair shop for an estimate first. --- or--
separate the base of the spool by pushing down on the gear like wheel and if you find the small crack from the bottom of the spool film slots, very carefully put a dab of super glue on the crack. check both sides of the spool. this works about 80% of the time. however it's better to replace the spool.
Advance lever and shutter stuck how do I fix it
Is there film in the camera? If so it may be at the end of the roll and thus when advancing the film it jammed. Rewind the film then see if the lever and shutter operate. If not then a CLA is needed.
Oct 28, 2013 | Pentax K1000 35mm SLR Camera
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
My pentax k1000 wont advance the film. How can I fix it?
First inspect the bottom of the camera, on the right side there should be the pin that you push in when you roll up the film. If it is not protruding while there is film inside then there is a issue with the mechanism.
If not then it may be an issue with the way the film is inserted. Is it a new problem or has it been an issue since you aquired the camera?
Feb 25, 2011 | Pentax K1000 35mm SLR Camera
I am new to this camera. My picture counter is loose and you can move it to different numbers. Is it broken? (because I heard that you should advance the film to "1" before you start taking pictures, but I...
It's broken. The K1000 will automatically advance the counter to the end of your roll. Removing the film and closing the back should reset it. If it's not doing that, it's broken.
Nov 03, 2017 | Pentax K1000 35mm SLR Camera
Loud grinding noise when I "****" the film.
kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Apr 09, 2008 | Ricoh KR-30SP 35mm SLR Camera
Film Advance Will Not move
Hi,powerpe. The mirror release rod can be located in the bottom of the body once the plate has been removed.(there are three screws on the old k1000's) There is a gear train on the left side when viewed turned over.The mirror cockong rod is towards the rear and a little right of the main shaft.You might need to move a little silver pawl with a pin or micro driver then you can push the mirror **** in to release the reflex mirror.the mirror cocking rod is about 1/8" dia.Hope this helps
Oct 21, 2007 | Pentax K1000 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Film advance
I don't suggest that you attempt to repair this yourself. The K1000 is a very solid camera and one that isn't very expensive to repair. Please do yourself a favour and take it to your local camera repair shop. You'll be glad you did.
Apr 16, 2007 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
164 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
