Question about Classic Coffee Concepts gb260 coffee maker stainless steel coffee
I NEED A THERMOSTAT SNAP ACTION 15/10AMP 120/250VAC (36TX31).
CAN'T ONE ONE ANYWHERE!!!
Can I use a household thermostat in an RV for heat and air?
As long as it is a 24 volt A/C system, which most are (look at the old thermostat in your RV) , and as long as it is a digital thermostat. Do NOT use one with mercury in it like the old round brown Honeywell that everybody has. The non-digital thermostats that use "snap-action" springs can be used, but they are mostly junk. Spend $35 on a decent digital and you will be fine.
Jun 05, 2015 | Heating & Cooling
Thermostat is not even close to accurate, must turn 10 degrees above to turn on and 10degrees below room temp to turn off
what type of t stat? if mercury bulb type make sure base is level on wall. If snap action line voltage replace it. If digital make sure cycle rate for your type of system is set correctly, and the ovious is it in a drafty location or being affected by a heat producing item being placed near it .
Nov 04, 2013 | Comfort Zone Heating & Cooling
Spray arm came off
These are simply a snap and push type of assembly in most units. You can find the shaft area of the sprayer arm and push and snap it back in place. You might need to use a slight tightening arm action to lock it into place - that is - unless you have any broken plastic pieces found in the unit. Then you need a new sprayer arm completely.
Dec 22, 2012 | Frigidaire 24 in. FDBB540 Built-in...
The heater does not work when switched on I have tested the cable up to the internal connection block and checked conntinuity through the thermoststat, all seem ok.Can you help
Someone stated this problem was a resistor located in the neutral side of power cord. That is where the problem is. However, it is actually a thermalink fuse rated at 10 amps. The heater pulls more than 12 amps. I wonder how many of these heaters have ended up in a landfill because of this manufacturing flaw!
Dec 21, 2009 | Lakewood Oil-Filled Electric Radiator...
York Heat Pump outdoor cutoff thermostat wiring.
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
Sep 05, 2009 | York Yankees Bedding MLB Comforter
Get message of fuser low therm 1F
One of the two small thermostats, that are called "snap-action disc thermostats" and control the electricity flow to the fuser lamps, has likely gone bad. If you are feeling generous to the money pit governed by Konica-Minolta, you'll need to replace the fuser unit. Otherwise, you'll probably need to locate and replace the bad thermostat. If you are not electronics saavy, I recommend taking the fuser unit to an electronics shop and asking them to check for and replace any bad thermostats.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. While in use, they keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. Once that happens, the thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
Jun 08, 2009 | Minolta magicolor 2200 DeskLaser Printer
Circuit breaker
I was able to get a replacement 5 amp MB-1 push to reset circuit breaker for my Flowtron LE-900 directly from Snap Action http://snapaction.net/ for no replacement cost and no shipping/handling cost. No one at Snap Action enquired as to what it was for, age, warranty, etc. (their MB1 product description indicates it to have a lifetime guarantee). I just had to mail them the defective original breaker - took about 2 weeks to receive the replacement.
Brett
Oct 16, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Digital camera driver
The link to driver of Che-ez Snap (it's virus-free as this is the official site) is here:
http://che-ez.at/stage/downloads/snap.exe
Just don't be surprised by the all German site. It is Austrian. Don't forget to give me thumbs up rating.
Good Luck.
Mar 17, 2008 | CHE-EZ Snap Digital Camera
Canon Powershot A75
I move the control dial on top of the camera from AUTO to the running figure for action shots, but there is still some delay - you need to snap the photo just *before* the shot is perfect
Dec 13, 2007 | Canon PowerShot A75 Digital Camera
Classic Coffee Concepts gb260 coffee maker stainless steel coffee Logo
53 people viewed this question
Top Classic Coffee Concepts Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Classic Coffee Concepts Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
