Kenmore tumble action washer problem
Hello Tom -
As of late, our 4.5 year old Kenmore tumble action washer (model # 41744142400) has been misbehaving. It starts fine, but does not advance to the next cycle. A rather loud humming is heard when the cycle is "stuck."
If I turn the dial just one click the next cycle will begin. This happens with each rinse cycle and the spin cycle.
Any ideas?
Thank you so much!
Joan O
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Repair pump on kenmores tumble action washer model 417 44152400
how do you know it is a pump? I'd
check with these parts suppliers. I believe I used their parts about 5 years ago. They were helpful
http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair/11-6-896091-/Kenmore-Washing-Machine-41744152400-Troubleshooting
Feb 13, 2015 | Washing Machines
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
No Motor Action / No Tumble or Spin / Kenmore 417 4405240
Yes, I am!!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Locked
if its 1 month old call for service your under warranty
Jan 05, 2009 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Jan 29, 2008 | Washing Machines
LOC message
thats a rotor lock position need to ck motor
Jan 08, 2008 | Kenmore 44102 Front Load Washer
Object lodged in barrel
Hi Amy, Check this link: http://www.repair-help.com/kb/index.php?article=177 Scroll down and under "ATTACHMENTS" it says: Console-Diagram.gif - Size: 36043 Control_Panel-Diagram.gif - Size: 61802 And you can click on either of those links and it's supposed to show you a picture of how to take your washing machine cabinet apart.
Nov 21, 2006 | Kenmore 44102 Front Load Washer
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
352 people viewed this question
Top Washing Machines Experts
