How do ya reset a compactlogix L23E QB1B plc - Office Equipment & Supplies
Where can I find thermal reset switch on my sanyo plc xu115? thanks
the switch should reset itself after it has cooled off, but it is typically near the housing of the bulb to read the temperature accurately.
Looks like this:
Feb 10, 2011 | Sanyo PLC-XU115 Projector
No power reset button on bottom?
There is a power reset for this device. It's a tiny hole on the bottom in between the lamp access door and the CAUTION label. If your projector gets a surge of power, instead of blowing a fuse, it just trips a little breaker inside the device and all you need to do is push a paper clip (unplug your device first BTW) into this hole and it will reset the breaker. Hope this helps.
Nov 25, 2010 | Sanyo Projector Lamp for PLC-XU100,...
Plc-xu105 will not restart. red on, no fans
SAYA MEMPUNYAI SANYO PLC XU105 , JIKA DIHIDUPKAN POWER LAMP MENYALA HIJAU BEBERAPA DETIK KEMUDIAN LAMPU WARNING LAMP MENYALA, KIRA KIRA KERUSAKANNYA DIMANA YA..? TOLONG YA SOLUSINYA..THKX
Feb 19, 2010 | Sanyo PLC-XU105 Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo PLC XU50
It may be that the lamp actually does need replacing so that may be why it's not coming on?
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
73 people viewed this question
k24674
jasbo
jasbo
