Question about Crystal Decisions Crystal Reports Server 11 (WFCWEWX00) for PC
Connecting crystal report with oracle through dsn/udl.
How can i connect a crystal report with oracle 10 g database through 'dsn' or 'udl' to make it more user friendly software.
3 Suggested Answers
  • 258 Answers
SOURCE: Loading images into Oracle database
You need to use a blob or cblob field to store a jpg file in Oracle
see this site http://asktom.oracle.com
Posted on Jan 14, 2009
SOURCE: Oracle ODBC connection shows no tables in Crystal Reports
i am also experiencing this problem. what i did was i created a new file in the repository folder (in crystal, when you create a new connection), containing the script that will pull all of my needed data.
Posted on Oct 08, 2010
Which database can I use with ColdFusion?
ColdFusion supports ODBC-compliant databases. With Net Nation's ColdFusion plans, you can use a Microsoft FoxPro, Microsoft Access or Microsoft SQL Server database. ColdFusion supports both DSN and DSN-less connections.
Oct 09, 2014 | Oracle 10g Database Standard (ODBSEONUPP0)
I want to install oracle 8i in windows 7, how i do this?
sir, i have a window7 in all in one hp but there is a software called mstar which run on oracle 8i when i install the oracle 8i there is a problem and show dll file corrupted. Pls tell me the solution because my client want it very urgently and i am not able to install and run the programm.
Feb 26, 2010 | Veritas Cluster Server for Solaris Oracle...
Oracle ODBC connection shows no tables in Crystal Reports, procedures only. I used to see them, but no longer. I can in Access so I know it is not the ID.
Aug 31, 2009 | Crystal Decisions Crystal Reports Server...
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
Apr 15, 2009 | Computers & Internet
HOW CAN I USE Crystal report in asp.net
In visual studio 2005 or 2008 crystal reports is present inside so right click in the project and add new item and select crystal report(.rpt) and select the database samething like gridview connectivity and select the table select row and columns of the table now u r crystal report is ready
Mar 07, 2009 | ComponentOne WebReports For ASP.NET...
Sir how to set a messagebox in vb.net
To display a MessageBox:
MessageBox.Show("This is your messahe text!", "Title of Your MessageBox", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Regarding connecting to an Oracle database, you'd have to search for the connection string.
Feb 15, 2009 | Keystone Active Server Pages (ASP)/Visual...
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Aug 13, 2008 | Xerox Office Equipment & Supplies
How to connevt visual basic with oracle(sql)
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Jan 23, 2008 | Computers & Internet
Open Questions:
Crystal Decisions Crystal Reports Server 11 (WFCWEWX00) for PC Logo
649 people viewed this question
Top Crystal Decisions Computers & Internet Experts
David Payne
David Payne
Are you a Crystal Decisions Computer and Internet Expert? Answer questions, earn points and help others
