Driver wireless tplink wn-350g - Computers & Internet
Driver TL-WN7200ND for windows 98 2E
System Requirements:
Windows 7(32/64bits),
Windows Vista(32/64bits),
Windows XP(32/64bits),
Windows 2000
no 98 support.
Apr 05, 2013 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
TPLink TG-3269 V3.2 not in gigabit speed although driver is updated
Did you make sure you that
  1. Your router LAN port supports GB Ethernet?
  2. You are using at least CAT5 cable? Try 5e or 6 if you have one. I've seen issues with older cables, where only 4 pairs where punched through (GB needs all 8 pairs)
  3. you checked the settings on the TPlink (especially Autonegotiation?)
let me know
Dec 02, 2012 | TP-LINK Gigabit Lan Card (10/100/1000)...
Connecting a tp link wireless usb adapter to xbox 360
It is not possible to use generic usb wireless adapters with the Xbox or Xbox 360 game console. By 8246b47.jpgJohn Anderson Jun 20, 2012
The post John Anderson is correct that this would not work with a XBOX device. These are intended for and installed on computers (laptop or desktop) with which you would need to install drivers for it on. There is supported drivers that will allow the installation of this device into either a XBOX or PlayStation gaming console.
Best Regards!TP-LINK Support Teamhttp://www.tp-link.com/us/supporthttp://www.facebook.com/TPLINK
Jun 20, 2012 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
TP-LINK TL-WN321G USB Wireless Adapter OSX Driver
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
http://download.cnet.com/realtek-rtl8187b-wireless-802/3000-2112_4-206215.html
hope it helps
May 22, 2012 | AGPtek TPLink TLWN321G USB 20 Wireless Lan...
I installed TP-Link WN7200 on Windows 7 Home Premium, the drivers is not digitally signed. The adapter is disabled and I can't enable it. There is no error in device manager. Please help me.
It is ok if the driver is not digitally signed. There's no need to worry.
To enable the adapter:
  1. Click on the Windows Start button
  2. Type in "network"
  3. Open "Network and Sharing Center"
  4. On the left bar, click on "Change Adapter Settings"
  5. Select your wireless adapter
  6. Right click on the wireless adapter then select Enable.
If you cannot select Enable, it means your adapter is already enabled. The adapter has a gray icon due to it not being connected to a router.
May 09, 2011 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
David Payne
David Payne
