Question about Cameras
Anyone dealt with a A99HW 35mm film scanner
I purchased one of these from maplins in November 08 and still have not figured out how to use it, all that come up on my screen after following the ibstructions are copies of the negatives themselves - NO photographs. can anyone advise me as to what I am (if at all) doing wrong
Have you installed the software and running the scanner through the software?
Please see the FAQ below
Alan (20/08/2009)Anyone dealt with a A99HW 35mm film scanner - 4-stars-small.gifThis works well scanning negatives when I eventually got it working on my Windows XP computer, the problem is the drivers, so did a search and found them here External link removed. The link can be requested via our technical department directly you need the one for XP only (FS-C1-VP). I also used an earlier version of Photo Impression6. I hope this is of help to many who have failed to get it running properly
So contact Maplin Tech support and they should be able to point you in the right direction of downloadable drivers or the correct procedure for installation and use.
Posted on Oct 12, 2009
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
Can i use any film for my Canon EOS Rebel SLR Mark 2 or will anyone work?
You can use any 35mm film in any 35mm camera. You must set the film speed (ASA or DIN number) on the camera to match what it says on the film. This is to get the correct exposure, as different films have different sensitivities.
Nov 22, 2010 | Canon EOS Rebel G-II 35mm SLR Camera
Lost film guids for canoscan 9900f. looking for
lost film guids for canoscan 9900f. looking for 35mm strips and slides 120 and 4"x5" format film holders in the accessory kit for canoscan 9900f
Apr 07, 2010 | Canon CanoScan 9900F Flatbed Scanner
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
I have bought a A99HW 35mm Film scanner from Maplins
There may be a newer versions of the software. What is the version you are using?
I take it that you get the unedited copies of the negative and not a photograph?
Jan 21, 2009 | Minolta Dimage Scan Elite Film Scanner
The back of the camera where you load the film will not close.
Thanks but no thanks to your service. I found a camera repair shop.
Dec 29, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Cameras Logo
246 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
