Question about Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD RW Burner
Push power button it lights up for 3second then shuts off what is wrong with it
  • 26 Answers
Could be bad ac adapter or bad motherboard. Have seen lots of cases where the ac adapter was bad and the laptop no longer starts after the battery goes dead.
Posted on May 19, 2014
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
Can I turn the lamp on fron a switched recpt or do I always have to push the button on the lamp?
I think you still have to push the button even if the power switch is on just to kinda get everything started, It will turn on the light & any neat movement &/or sound effects that it makes will happen & if it's anything like my daughters lamp that's similar to this, if you push the button a second time, music and sound will happen again but then the light will shut off. I'm not positive that i'm correct & apologize if i'm wrong but my daughter has a Disney dancing princess lamp & thats how it worked. It also had a switch to turn on or shut off the sound so i hope I helped somehow now that i've written a novel that should have been 1 or 2 sentences. Sorry
Jul 03, 2011 | KNG America KNG Disney Fairy's Animated...
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Baterie is dead, while under charge the headlight are on, the engine wont turn?
well.. you could blow something up if you hook the charger up wrong by accident.. but that is unlikely.
it sounds like you have a short somewhere or your ignition could be worn out.
but before you consider that i would check the simpler things first.
i dont quite understand your description but i will take a shot at it..
if the cab lights stay on when the key is out you need to check the little button that both doors push in when they shut that lets the cab lights turn on when you open the door. for both doors
check the button that your glove box door hits to shut the light off and make sure the lights off when you push it.
just find those buttons and push them in and the lights should shut off.
let me know if im on the right track
Apr 08, 2010 | 1994 Ford F150 Styleside Supercab
Power side power on 2000 sienna van does not work
Sounds like the switch in the door, that tells the car the door is closed, is not working or broken. It may be inside the door or on the door frame. It looks like a button or a slide button that when the door closes, it's supposed to close on this button and shut off the interior lights and turn off the dash light. The doors probably won't lock because it thinks the door is open with the keys in the ignition. Electrical systems are never cheap to fix and they can cost a lot of time just to figure out exactly what's wrong and where. I hope this helps.
Feb 25, 2009 | 2004 Toyota Sienna
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Power button problems
The round button should light up when printer is on. Push it and the light goes off and so does the printer.
Jun 12, 2008 | Lexmark X2500 All-In-One Printer
Lap top will not power on
repair shop job- button replacement if possible.
May 15, 2007 | HP Pavilion ze5185 Notebook
Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD RW Burner Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
