Question about Mitel 5340 IP Phone
Application loading on screen - Mitel 5340 IP Phone
Whean I am goas to turn on my mobile Blackberry RIM 7290 that time mobile is showing TCU EXCEPTION RESET messege.What shoud I do for solve this problem.Pls help me.
Download and install the latest BlackBerry Device Software.
1. Download the latest version of BlackBerry Device Software from your wireless service providerxxx8217;s website.
2. Connect the BlackBerry device to your computer.
3. Open BlackBerry Desktop Manager and double-clickApplication Loader. The Application Loader Wizard opens. Click Next.
4. If prompted, enter your device password and clickNext. The Application Selection window appears.
5. Select the applications to be loaded on to the device, then click Next.
6. The Completing the Application Loader Wizard screen appears.Do not click Finish. Click Advanced to begin loading the applications.
7. In the Data Preservation window, select the Erase all application data and Erase all currently installed applications check box and clickNext.
8. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete.
9. Click Finish to begin the Application Loader Process. The data on the device is erased and reloaded.
10. Click Close when the loading operation is complete.
Mar 01, 2011 | RIM BlackBerry 7290
My blackberry had error code 200 and now it only has small menu and everything gone blank,how do i reset the software on it.
hi murphy201 and welcome to fixya,
re-install the BlackBerry device Software and applications to the BlackBerry smartphone, try this steps: first, connect the blackberry phone to the computer and open Blackberry desktop manager double click Application loader, you may need to unplug and re-attach the USB cable to the phone for it to e recognized by application loader then click next, choose the port that the blackberry phone is connected and click next if prompted, type the blackberry smartphone password and click next. The device application selection screen appears. Select the applications to be loaded onto your Blackberry phone. If the device backup screen appears, choose whether or not to automatically back up the Blackberry Smartphone, click next. wizard screen appears displaying all the software will be loaded to your phone click the advanced button and make sure that erase all application data and erase all currently installed applications are both selected. Pls. take note that if the application loader was not able to access all of the Blackberry smartphone data, then both erase all application data and erase all currently installed applications will be grayed out. Click next, Click Finish. The device software will be loaded on your phone. Do not disconnect until the process has completed.
Thank you and have a nice day
Jan 06, 2011 | RIM BlackBerry Curve 8520 Smartphone
App error 200
Well first of all you can try the following -
The "APP Error 200 Reset" indicates that your device firmware needs to be erased and reloaded. To perform these tasks please follow these steps:
1. Connect the BlackBerry smartphone to the computer.
2. Open BlackBerry Desktop Manager.
3. Double-click Application Loader. The Application Loader Wizard appears. You may need to unplug and re-attach the USB cable to the BlackBerry smartphone at this point for it to be recognized by Application Loader.
4. Click Next.
5. Choose the port that the BlackBerry smartphone is connected to and click Next.
6. If prompted, type the BlackBerry smartphone password and click Next.
7. The Device Application Selection screen appears. Select the applications to be loaded onto your BlackBerry smartphone.
8. If the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry smartphone. Click Next.
9. Click Next. The Completing the Application Wizard screen appears, displaying all the software that will be loaded to your BlackBerry smartphone.
10. Click the Advanced button and make sure that Erase all application data and Erase all currently installed applications are both selected. Note: If the Application Loader is not able to access all of the BlackBerry smartphone data, then both Erase all application data and Erase all currently installed applications will be grayed out.
11. Click Next, and then click Next again.
12. Click Finish. The BlackBerry Device Software is now loaded on the BlackBerry smartphone. Do not disconnect the BlackBerry smartphone until the process has completed.
Post comments for further help or information.........
Good Luck!!
Mar 26, 2010 | Cell Phones
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
What can i do for app error 523
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
I hope i was able to help you.
Oct 13, 2009 | RIM BlackBerry Pearl 8100
Blackberry device error 411. I also had a strange
Before Perfoming these steps take a Back up of your Handset. Cause 1 The wireless transceiver software was not loaded onto the BlackBerry device correctly. Resolution Re-install the BlackBerry Device Software using BlackBerry Application Loader. Connect the BlackBerry device to your computer. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next. If prompted, enter your BlackBerry device password and clickNext. The Application Loader Wizard examines your BlackBerry device?s current configuration. When it is finished, the Application Selection window appears. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears. Do not click Finish. Click Advanced to begin loading the applications. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete. Click Finish to begin the BlackBerry Application Loader process. Click Close when the loading operation is complete. Cause 2 There is a wireless transceiver hardware failure. Resolution Contact your service provider for more information.
Mar 24, 2009 | RIM BlackBerry 7290 Smartphone
Blackbeery 7290 every time I turn the radio on it reboots why?
Cause Summary of Causes
  1. The wireless transceiver software was not loaded onto the BlackBerry device correctly.
  2. There is a wireless transceiver hardware failure.
Cause 1
Resolution
  1. Connect the BlackBerry device to your computer.
  2. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next.
  3. If prompted, enter your BlackBerry device password and clickNext.
  4. The Application Loader Wizard examines your BlackBerry device’s current configuration. When it is finished, the Application Selection window appears.
  5. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears.
  6. Do not click Finish. Click Advanced to begin loading the applications.
  7. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext.
  9. Click Finish to begin the BlackBerry Application Loader process.
Cause 2
Resolution
Mar 02, 2009 | RIM BlackBerry 7290
What does app error 523 mean and and how can i fix it?
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Procedure
6.Click Next.
9.Click Next.
Good Luck and do let me know
Feb 28, 2009 | RIM BlackBerry 7100G Smartphone
Can't run applications from an expansion card
In some cases, applications developed before Palm OSĀ® 4.0 that are loaded to an expansion card may encounter errors when launched. However, these applications generally run properly when installed directly to your handheld's internal memory. Here's how to do that: 1. Access the Applications launcher. 2. Open the Menus. 3. From the App menu, select Copy. 4. In the Copy To: pulldown menu at the top of the screen, select your expansion card. 5. In the list of applications, locate the file you want to copy to your handheld's internal memory. Highlight the file. 6. At the bottom of the screen, select Copy. Then select Done. 7. Go back to the Applications launcher. At the top right of the screen, there's a pulldown menu with different application categories. Choose All (this is a category that's on your handheld, not on your expansion card). 8. Locate the application you copied, and launch it from this screen. 9. Contact the developer of the application for more information on application compatibility with expansion cards.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Mitel 5340 IP Phone Logo
37 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
