Question about HP PSC 2210 All-In-One InkJet Printer
How do I install the new cartridge latch (color) of my HP PSC
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How do I install the new cartridge latch (color) of my HP PSC 2210 all-in-one printer?
  1. Can I access on on-line repair manual?
  2. Can you walk me thought the process?
  • 32 Answers
You will need a small TORX screwdriver (star shape) to remove 3 screws.
see my post @ techtalkz.com/hp/124170-hp-psc-2210-cartridge-latch.html
Posted on Nov 19, 2009
How do i remove the ink cartridge ?
Turn on the unit, then open the print-carriage access door by lifting
the handle until the door locks into place.
The print carriage moves to the center of the unit.
You may want to use a photo print cartridge for
superior print quality when printing photos. With the
color and photo print cartridges installed, you have
a six-ink system. See how to print the best quality
photos on page 22 for more information.
52 maintain your hp psc
hp psc 2200 series
2 After the carriage stops moving, lift the latch to release the print
cartridge, then pull it toward you out of its slot.
3 If you are removing the black print cartridge in order to install the
photo print cartridge, store it in the print cartridge protector.
4 Remove the new print cartridge from its packaging and, being careful
to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5 Push the new print cartridge into the appropriate slot until it clicks into
place.
The tri-color print cartridge goes on the left and the black or photo
print cartridge goes on the right.
manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01176633/c01176633.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
Where can I buy the cartridge latch that hold the ink cartridge in place for a hp psc 2210 all in one printer
You will have to probably buy the whole assembly it will cost a lot. Try to find a used broken machine or partsurfer.hp.com will be your best bet. Steven 818-888-0006
Mar 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP 6110 check cartridge error won't clear with new cartridges. Anyone know how to fix this?
You could try this way first as its a lot quicker and easier than the official steps from HP:
Just hold down the ENTER button and then press the MENU button. There will be a series of 3 fast, high beeps. Then everything resists and is a-okay. Both problems go away.
OR The HP way as listed below:
The ink cartridge-related error messages may occur due to one
of the following reasons:
* The ink cartridge does not make a proper electrical contact
* The cartridge is bad or wrong
* The cartridge is remanufactured or refilled
To resolve the error, follow these steps:
Step one: Check the print cartridges and clean the cartridge contacts
Even if the cartridge is new, follow these steps to clean the print
cartridge contacts. Print cartridges have a substance on the contacts
to keep them from corroding during storage that may cause poor
electrical contact between the print carriage and the print cartridge.
1. Verify that the product is turned on.
NOTE: If the HP product is not turned on, you will not be able to
remove the print cartridges.
2. Open the top cover or the cartridge access door in one of the
following ways:
* Pull the control panel forward and then lift the top section
toward the back.
* Open the access door on the left or right of the unit. This door
may be located under the scanner glass lid on some flatbed
products.
* On many flatbed products, you raise the front center section of
the unit to access the print cartridges.
* Raise the cartridge access door on the front of the product.
3. After the print carriage stops moving, unplug the power cord. You
must unplug the power cord to prevent the print carriage from
moving.
4. Remove both print cartridges.
5. Verify that the part number on the cartridge is the correct part
number for the all-in-one and that the carriage is not blocked
preventing the cartridges from moving. Visit the following HP Web
site for a cartridge compatibility chart.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpa00586
6. The electrical contacts of the print cartridge are coated with a
thin layer of grease to protect them from oxidation. This grease
may inhibit the electrical connection and should be removed. Using
a cotton swab or cloth lightly moistened with distilled, filtered,
or bottled water, clean the electrical contacts of the cartridge.
This usually occurs with a new ink cartridge, but may also occur
with an older cartridge.
NOTE: When an all-in-one is used frequently for black and white
printing but infrequently for color printing (for example,
an all-in-one that is used primarily as a fax machine), the
color cartridge will still eventually fail and need to be
replaced. The pins in the print carriage can cause dents
on the contact points of the color cartridge over time
(usually between six and twelve months).
7. Wipe the contacts with a dry, cotton cloth.
8. Reinsert the cartridges and lock them in place.
9. Close the top cover or access door and plug in the power cord.
10. If the error persists, repeat these steps. If further cleaning
fails to resolve the error, proceed to "Step two: Clean the
print carriage contacts" section.
Step two: Clean the print carriage contacts
Have the following materials available to clean the print carriage
contacts:
* Cotton swabs or any soft material that will not come apart or leave
fibers (for example, a scrap piece of clean cotton cloth).
* Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
CAUTION: Be careful not to get ink on hands or clothing.
To clean the cartridge contacts inside the product, follow these steps:
1. Turn on the unit.
2. Open the top cover or cartridge access door.
5. Using a cotton swab or cloth lightly moistened with distilled,
filtered, or bottled water, clean the electrical contacts of the
print carriage.
6. On models equipped with locking latches, lower the latches.
7. Wait five to ten minutes for the contacts to dry and then plug in
the power cord. The unit will begin to reinitialize. Wait until
the process is complete before proceeding.
8. Reinsert the print cartridges when prompted and then close the top
cover or access door.
9. If the message recurs, replace the print cartridge indicated by the
message.
* If you are using refilled or remanufactured cartridges or non-HP
cartridges, replace them with new HP cartridges. HP cannot
guarantee that refilled or non-HP cartridges will function
correctly in HP products.
10. If the problem still exists, replace both print cartridges. Since
the cartridges are electronically connected through the printed
circuit board, the cartridge not indicated in the message might be
the causing the failure.
If the issue still persists, please click on the link below and install
the firmware update:
ftp://ftp.hp.com/pub/softlib/software3/COL4415/oj-14700-3/HpAiOFWUpdate2_2.exe
NOTE: Clicking the link may give an error indicating it is
invalid. If this occurs, copy the portion of the address
on the remaining line(s) and paste it at the end of the
address showing in your browser until the complete address
is displayed in the Address box.
1. Download the file "HpAiOFWUpdate2_2.exe" to a local hard drive. Make
note where (in which folder) the file gets copied.
2. The hp all-in-one software for the OfficeJet 6100 series must be
installed on your PC before installing this firmware update. The
OfficeJet 6100 series must also be connected to your PC and turned on
before proceeding.
3. Locate the file "HpAiOFWUpdate2_2" on your hard drive and
double-click the file to install the firmware update.
This should resolve the issue. If you need further assistance, please
reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support
experience. We would appreciate your feedback.
Please visit our Owner Services Web site for details on keeping your HP
and Compaq products up and running.
http://www.hp.com/home/ownerservices
I hope this helps
Mike
Jun 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer Cartridge cover broke off
No, sorry. Small parts are not available.
Feb 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 print cartridge won't align
Press and hold the Setup button.
Press the Options button. The printer should be ready to print.
Nov 24, 2008 | HP PSC 2210 All-In-One InkJet Printer
Ink cartridges
Click on this link for cartridge installation instructions. There is also an animation link on this page.
PSC2210 Ink Cartridge Install
Make sure you use #56 (Black) and #57 (Tri-color) cartridges.
Nov 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 printer carriage
Part #'s are
ASSY-LATCH BLACK - C6490-60011
ASSY-LATCH COLOR - C6490-60012
Parts re-sellers for HP:
United States Big Blue Products, Inc.
Huntington Station, NY
Tel: 888-BIGBLUE
http://www.bigblueonline.com/hp.htm
Bradshaw Group, Inc.
Richardson, TX
Tel: 972-644-7558
http://www.bradshawgroup.com
Computer Exchange LTD
Lawrenceville, GA
Tel: 770-806-3939
800-883-0800
http://www.computerexchangeltd.com
Depot America, Inc.
Farmingdale, NJ
Tel: 800-648-6833 or 732-919-0209
http://www.depot-america.com/
Image1 Products, Inc.
Plano, TX 75074
Tel: 866-846-2431
http://www.image1products.com
Laser Pros International
Rhinelander, WI
Tel: 888-558-5277 or 715-369-5995
http://www.LaserPros.com
Masterworks International Inc.
Houston, TX
Tel: 800-695-2282
Fax: 713-896-0885
sales@mwintl.com
http://www.mwintl.com
Parts Now!
Middleton, WI
Tel: 1-800-886-6688 or 608-276-8688
http://www.partsnow.com
System Design Advantage LLC
Bloomington, MN
Tel: 1-800-947-0007
http://www.sdallc.com
TSAworld, Inc.
Norcross, GA
Tel: 800-633-6626 or 770-417-2323
http://www.tsaworld.com
Vance Baldwin Electronics
Fort Lauderdale, FL
Tel: 954-723-9191
http://www.vancebaldwin.com
Jan 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
May 14, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
321 people viewed this question
Ben Johnson
