Question about Kenmore 22422 Top Load Washer
Timer and possibly more.
99% sure my timer's shot on my 70 series kenmore washer (have been manually turning nob). but would this cause water flow to stop? if not, what other problems may i be looking at?
    Genius:
  • 2,920 Answers
Yes it an cause the water flow to stop....your best bet is to buy another timer and put in or get another washer.
Posted on Jan 21, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Is there a fuse for the 70 series washers? Mine wont spin the water out...
No user-servicable fuse that I'm aware of -- I sell Kenmore appliances. If it won't spin out water, it's probably a bad pump. Does the motor run? Can you manually advance the timer? If so, you may have a bad timer.
Oct 17, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore 70 series top loading machine will not drain and go into the rinse cycle what part needs to be replaced?
CHECK THE LID SWITCH, AND CHECK THE TIMER FOR A BURNED SMELL. IF SMELL PROBABLY TIMER. SOME WASHERS WOULD NOT GO INTO SPIN WITHOUT LID CLOSED, BUT WOULD AGITATE.
Mar 10, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore 70 series washer. Water will not shut off. Is it a shut off switch and can I order that part?
Either could you have a bad water valve or bad timer. If the water is over flowing when you start it and not shuting off you could have a bad pressure switch or bad air hose from tub.
Sep 21, 2009 | Kenmore 24932 Top Load Washer
Kenmore 90 series wont advance to next cycle
Yes, most likely but to be sure you can check voltage at the timer assembly 2 small black wires coming out of the timer.....
Jul 01, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Washer produces Hot Water Only
first be sure you are getting a good flow of cold as far as the washer connection..if so ck inside washer connection for a small wire screen be sure it's not plugged if so clean and flish line to remove anything inside hose ..be sure to put screen back in ..if still no cold suspect bad cold section of valve..replace valve..last remote possibility temp switch is bad
Sep 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore 22422 Top Load Washer Logo
116 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
