Question about Poulan Pro 25cc 2-Cycle Gas Blower BVM200FE
Wont start acfs like flooded; spark plug wet with gas
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: wont start,was runing two days ago,have fresh gas,checked plug
Your carberator should be taken apart and cleaned with carb cleaner or solvent for at least an hour. Also check that your fuel hose isn't kinked. If your plug is not wet, then that means it isn't getting any gas to cylinder.
Posted on May 09, 2009
  • 248 Answers
SOURCE: Poulan pro 4218 avl, starts (sometimes) then dies,
may be choke problem,about 20.00 for repairman to fix
Posted on Oct 08, 2010
  • 97 Answers
SOURCE: i have a poulon pro
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Posted on Aug 28, 2011
Have replaced plug gets blue spark plug is wet with gas but wont start
Then it's flooded. Wait an hour or so and try again.
Feb 13, 2015 | Cars & Trucks
2006 liberty cranks but wont start
gas engine, not diesel.
its probably flooding, ever give it a 60k mile tune up, ever?
we check spark tips for flooding and dry,never do we guess at fuel pumps, ever. (pressure gauge is $20)
tips dry or soaking wet.
we check for spark , no gas engine car runs with no spark
so we check all cylinders for good spark
if spark is good and flooding (new spark plugs) we use
cranking wide open throttle wot. like the operators guide says.
start now? this cuts all injection, this magic PCM trick.
see scotty ,
1: compresson at spec, 2: spark good and timed. and 3: fueling last.
skip the silly ad.
note he says 2, but he ASSUMES compression is good. (oops)
but his tests are fast, and if it fails to start, see #1 above. ask
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Feb 27, 2014 | 2006 Jeep Liberty
My 2000 Chrysler 300m wont start it turns over but wont fire its getting gas but wont fire
Are you certain it's getting gas, does it smell flooded?
Pull one of the plugs, see if its wet after cranking.
Ground plug and check for spark, if no spark, problem could be crank sensor or coil packs.
Aug 30, 2013 | Chrysler Cars & Trucks
98 RAM 1500 WONT START
Replace the coolant sensor NOW!? Its causing a flooding condition as evidenced by wet plugs that short out when flooded. Blip the starter and see if raw fuel is blown out as another indication of a flooded condition. In cases of flooded engines, holding the gas pedal to the floor shuts off the injectors during starting to clear out the cylinders.
The brass replacement sensor will cure flooding and many other engine/transmission issues.
Nov 18, 2011 | Cars & Trucks
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Crank no start ,got fuel got spark, when trying to start spark plugs get wet ,changed plug pinched fuel line shut try srarting flud wont start???
You pinched the fuel line????
If you crank for too long to start the car, the engine will "flood", this is why the plug was wet. It had too much gas and wouldn't start.
Pull out ALL plugs and dry them off.
Install them.
HOLD your gas pedal to the floor and crank.
This will stop gas from entering the engine.
you need to get that extra gas out beofre it will start.
If you have so much gas in there you can do damage to your engine!!
Now after a few crnaking attempts with your foot to the floor, take your foot of the gas pedal and try to start it again.
But remember if it doesn't start in 3 tries, you need to do the pedal to the floor once or twice to remove the excess gas.
When you crank the car to start it sprays gas into the engine, even if it won't start. So it very easy to "flood" the engine, and then you'll have a hard time to get it going!
Jan 08, 2010 | 1997 Nissan Sentra
I have a pit bike 125 its not starting wot so ever got good spark but still not start
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Apr 22, 2009 | RTO Pit Bikes
Poulan Pro 25cc 2-Cycle Gas Blower BVM200FE Logo
49 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
