Question about Datascope PASSPORT EL ECG unit
Unable to change date and time on EL model - Datascope PASSPORT EL ECG unit
HOW DO I CHANGE THE DATE AND TIME?
Only the EL-1197PIII has time and date settings, so I assume you own this model. A link to the manual is here: http://www.sharpusa.com/~/media/96B576A9DADF49A0B1321B57CAB1741D.ashx
You can find the time and date set up process on the first page, 3rd column, 2nd paragraph, under the headline GRAND TOTAL/RATE SETTING MODE SELECTOR.
Feb 11, 2010 | Sharp EL-1197P Calculator
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
Can't set time, date or rate
for 2/2/09, enter 2.2.2009 and then hit the button with the clock symble.
Nov 03, 2008 | Sharp EL-1801P Calculator
Time date
i know i set this model before but i recently tried to again and it didn't work right for the time for some reason... but i do remember that you flip the middle switch to rate set, the you put in the date 12.10.08 seperated with a "." then you hit the time date button once. then you do the same with the time, hours(militarytime).minutes.seconds all seperated by a period I.E if it were 1:30 PM you woud put 13.30.00, then you hit the time button again.. the date and time should be set, might have to do it in the opposite order... but i know that is generally how its set
Oct 27, 2008 | Sharp EL-1801P Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Mar 10, 2008 | Sharp EL-2196BL Calculator
Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
Jan 23, 2008 | Columbia All Sport Digital watch
I dont know how to set the time and date on my watch{arnette model ar 2041}
do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
Jan 15, 2008 | Watches
Datascope PASSPORT EL ECG unit Logo
80 people viewed this question
Top Datascope Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Datascope Health and Beauty Expert? Answer questions, earn points and help others
