Question about Transcend TS-RDF1 ExpressCard Reader
Driver doesn't load after reboot
Need expansion card software
Driver and info can be found here :
http://www.transcend-info.com/Support/DLCenter/index.asp?LangNo=0&Show=&axn=SRH2&FldNo=7&CatNo=210&ModNo=283&ItemID=TS-PDU3#detail
Jan 15, 2013 | Transcend Usb 3 0 Adapter Pcie For Desktop...
Tip
How to Install a ExpressCards into your laptop
When we enjoy a weekedn with our family and shoot many pictures. We want to store it in our laptop battery and share with any other friends with email. We use the ExpressCard to connect the camera memory card with the laptop. Also ExpressCard plug-in hardware available includes TV tuners, mobile broadband cards, FireWire 800 (1394B), Serial ATA external disk drives, solid-state drives, wireless network interface cards, TV tuner card common access card (CAC) reader and soundcards. Media remote control units are available that use the ExpressCard slot to store and recharge battery4.us. So we must at least know how to remove and install a ExpressCards.
How to remove an ExpressCard or Blank
Inface removing an ExpressCard is a very easy thing. You can complete it only by two steps:
1.Press the card or blank to remove it from its slot.
2.Save a blank to use when no ExpressCard is installed in a slot. Blanks protect unused slots from dust and other particles.
How to install an ExpressCard or Blank
You can install Express Card while the computer is running. The computer automatically recognizes the card.
ExpressCards are generally marked with a symbol (like a triangle or arrow) or specify a label, which end in the slot to connect. The cards are keyed to prevent incorrect insertion. If the map orientation is unclear, consult the documentation that came with the card.
To install an ExpressCard:
Keep the card shows the top of the card facing up.
Insert the card into the slot until the card is fully engaged in the port.
If you encounter too much resistance, no force. Check the card orientation and try again.
The computer recognizes the ExpressCard and automatically loads the appropriate device driver. If the setup program tells you to load the drivers from the manufacturer to use the media that came with the Express card.
on Aug 03, 2010 | Computers & Internet
Need driver for ExpressCard reader for mac
I don't understand why company's make these things so hard to find sometimes...
There's a MAC Os Driver on their website:
http://www.transcend-info.com/Support/DLCenter/GlobalDownload.asp?Model=ExpressCard%20Reader%20F1&Type=MacOS%2010.x%20driver&URL1=Driver&URL2=TSRDF1_Mac.zip
If you looking for a way to navigate there yourself:
Go Here: http://www.transcend-info.com/Support
Click Download
Select: Card Readers ' Accessories ' RDF1 ' TS-RDF1
Jan 04, 2013 | Transcend Express Card Reader for...
Windows can't access my Transcend 16gb SSD Express Card.
did windows ever recognise your transcend 16 gb
this might be a driver related problem
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Oct 18, 2011 | Transcend 16Gb Expresscard Ssd Mlc...
SD Reader doesn't load driver
Are you receiving an error message - what is it?
Did you download the latest driver from Sony web site?
Runing Vista? http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTZ195NXC&upd_id=2785&os_group_id=10
Try going to device manager and deleting the hardware that has the excamation mark before loading the new driver. Reboot if the system asks you to. When you restart, it may redetect and ask for a driver... click cancel.. Install the new driver at this time, reboot... it should now work.
Aug 24, 2011 | Sony VAIO VGN-TZ195N/XC Cen Core 2 Duo...
Where can I find drivers and BIOS updates? Transcend websites do not indicate support of motherboards.
When you search on the transcend site for your MoBo it states quite clearly contact support.
Need I say more?
Oct 10, 2009 | Transcend TS ABD4 Motherboard
Transcend pendrive
you just uninstall that unkown device which you get in device manager and reconnect the pendrive if again it says unknown device then goto update driver and select 2nd option which is advanced in that select don't search for driver i'll select and select the driver which is shown in the list and click next and finish ur pendrive will works
Jul 08, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
My 64gb pen drive trascend asking for formet
Barring a physical hardware issue, this may have an encryption applied by the manufacturer that is dycrypted by their software or driver. Check with the manufacturer.
Jun 22, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Usb driver motherboard transcend win 98
check your docuentation. Check if its compatible with Windows 98. If its not then no driver is made for this.
Sep 14, 2007 | Matsonic MS9367E Motherboard
Transcend TS-RDF1 ExpressCard Reader Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
