Question about Casio MTP3050D Watch
HOW DO I TAKE OUT THE LINKS ON MY CASIO MTP -3050
What battery does a casio mtp 1246 take?
Take your Casio watch to a jeweler for battery identification and replacement.
Jun 21, 2017 | Casio Watches
How do I remove the back from my Casio MTP-3036?
You need a tool like this. Be aware if you open the watch it won't be water tight and can't be used under water again. Even a jeweller can do the damage to your watch. To keep it water tight you should go to or send it to a Casio certified repair centre.
Jun 03, 2012 | Casio MTP Watches
How do I adjust casio module no. 3050 watch band-steel
Your casio MTP3050D 2AV had a module number of 2719.
If your looking for module 3050 here is the link.
If your looking for module 2719 here is the link.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 17, 2011 | Casio MTP3050D Watch
How to put back the back cover of caio watch MTP-2144
mcdevito75 Here, That back cover should have 4 screws to hold the back cover onto the caseing. Donot apply pressure to that back cover or you may destroy the LCD face of your Casio. Use a tweezers to place the screws and gently screw down back cover.
Sep 24, 2010 | Casio Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Casio MTP3050D  Watch Logo
    44 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
